01-02-2010, 09:16 PM | #23 | |
I'm kind of a bitch
400
Rep 895
We are going to have to have it all drawn out anyway. For drawing out the plans in the yard and everything, do we hire a building architect or a landscape architect? Or one to draw the garage plans and another to do the yard? I'd like to get the plans done for the yard at the same time if we can.
E93: Montego/Cream <---- E46 (Coupe): JB/Black <---- E30 (Cabrio): Alpine White/Black
01-03-2010, 09:40 AM | #24 |
188
Rep 3,415
I built a 26 x 30 pole barn for about $32K in 2004. That includes framing with 6x6 PT poles, 9" concrete pad (12" underneath my lift), OSB siding, Hardie Plank (concrete siding) outside siding, steel roof and eaves, coupla, one 8' sliding door, one 8' swingout door, and one 36" entry door. I found a good deal on new (never used) windows at a junk dealer and I got another one from a consignment shop. It also has a storage loft. I bought the plans off the internet for $20. The plans were complete and the county only made me change the framing for the loft floor from doubled-op 2x10's to doubled up 2x12s.
There are a lot of good plans for garages on the web. If you want it integrated with the house then an architect is the way to go. I didn't need to match my house. It is a freestanding building. |
01-03-2010, 10:03 AM | #25 |
1er Happy Camper!
29
Rep 474
I'm having a house built now and the garage is built-in, so I can't comment on the cost of the garage. I thought I would toss in a couple ideas to consider.
I am having the builder include some 'blocking' at a couple points. Blocking is putting plywood or regular wood between joists or trusses under the drywall. It allows you to mount things anywhere along the blocking without having to worry about finding studs to screw into. For me, I'm having the narrow wall between the two garage doors blocked to allow mounting a vacuum and other goodies as well as a section of the ceiling between the two bays to allow for an automatic fire extinguisher, drop light, air hose reel, etc. Not quite exactly the same, I am looking at reinforcing parts of the trusses to allow me to use the ceiling for overhead storage. In most states, the requirements for ceiling load limits are zero, meaning they are not rated for any additional load. If you want to utilize that, you should ask about reinforcing it. Whether you heat the garage or not, insulation in the walls is relatively cheap and you will definitely notice it if you spend any time in there. My 2 cents - good luck with your project. Have Fun, Rick
2009 135i (E82) Space Gray; Gray Leather; Steptronic w/paddles; Premium; Sport; CA - Dinan: Stage 2 ECU; Cold Air Intake; Oil Cooler; Susp. bushings; Strut Brace. - BMWPerf: Suspension; rotors front & rear; exhaust; grilles; sideskirts; trunk spoiler. BMW 261M wheels w/Sumitomo HTR ZIII. - Quaife: LSD. - Custom Graphics.
2007 X3 - 2002 Pontiac Montana |
01-03-2010, 01:18 PM | #26 |
Registered Sex Offender
617
Rep 4,757
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
01-03-2010, 01:55 PM | #27 | |
313
Rep 2,576
