      02-12-2009, 09:34 PM   #23
nnnnnnnnnnnnnnnnnnnnnn
114
465
Drives: 1
Originally Posted by Nikki View Post
Dude i posted the solution idiots
no you didn't. There are 2 that aren't intersected.
      02-12-2009, 09:34 PM   #24
aut0sh0cker
meh
aut0sh0cker's Avatar
125
1,752
Drives: E92 335i, 997.2 C4S
Line Segment (as defined by geometry): a line segment is the sum of all point on a line between two given endpoints
Depending on who wrote this problem, those points on the lines that are clearly shown may or may not be considered "end points"
      02-12-2009, 09:35 PM   #25
oldaccount
oldaccount's Avatar
171
2,455
Drives: Car
ferrari missed top right corner segment.
nikki missed missed 2 in the middle.
so no, you didnt solve it.
      02-12-2009, 09:35 PM   #26
114
465
Drives: 1
post the answer already.
      02-12-2009, 09:36 PM   #27
114
465
Drives: 1
I know, look at the post below the first one...
      02-12-2009, 09:36 PM   #28
radix
you know he kills little girls like you
radix's Avatar
403
892
Drives: -
No, you didn't because you intersected the outer right line twice.
      02-12-2009, 09:37 PM   #29
aut0sh0cker
meh
125
1,752
I would... if i knew how to draw it...
I am on a Linux computer right now doing some CS work and I dont really know how to use it outside of Terminal haha
      02-12-2009, 09:38 PM   #30
radix
radix's Avatar
403
892
Drives: -
Originally Posted by Railgun View Post
In Andrewland, sure. In reality, not so much...
Here's whatcha missed...
You don't know what a line segment is. Look at this plus sign:
an addition sign is created by two intersecting line segments not four. So, while your attempt at sarcasm is humorous, it's also wrong. So again, I already posted the correct solution as I intersected every line segment in the puzzle only once, with one continuous line.
      02-12-2009, 09:42 PM   #31
radix
radix's Avatar
403
892
Drives: -
Try gimp. i.e.
$ gimp
      02-12-2009, 09:43 PM   #32
114
465
Drives: 1
then you didn't solve it.
      02-12-2009, 09:45 PM   #33
oldaccount
oldaccount's Avatar
171
2,455
Drives: Car
youre apparently confused as to what a segment is.
      02-12-2009, 09:47 PM   #34
radix
radix's Avatar
403
892
Drives: -
No, I'm not, from Wiki:
"In geometry, a line segment is a part of a line that is bounded by two end points, and contains every point on the line between its end points."
The addition sign is created by two intersecting line segments.
      02-12-2009, 09:50 PM   #35
radix
radix's Avatar
403
892
Drives: -
Huh?
seg·ment (sěg'mənt)
n.
Any of the parts into which something can be divided:
Mathematics
The portion of a line between any two points on the line.
Sarcasm isn't as funny as someone who really thinks everyone else is wrong.
Again, from Wiki:
http://en.wikipedia.org/wiki/Line_segment
and I don't think everyone else is wrong in this case, just you.
      02-12-2009, 09:55 PM   #36
oldaccount
oldaccount's Avatar
171
2,455
Drives: Car
if you think there are only 8 line segments in this puzzle then you completely are missing the point of the game. the perimeter of the yellow area has 9 segments alone. any 2nd grader could draw a continuous line through each one of the 'lines.'
      02-12-2009, 09:55 PM   #37
radix
radix's Avatar
403
892
Drives: -
Does that box look like an addition sign? WTF?
Here's the answer. NO! See the points within that drawing. Everything between each point is a segment. It's a plain fact.
No... every point between the two endpoints is on the line segment, as per the definition of line segment, the endpoints are at the *gasp* end of the drawing. Two intersecting lines or line segments share a point by definition. Just because two lines intersect it does not by definition create a new line segment because the point at which the segments intersect was already a point on one of the existing line segments.
      02-12-2009, 09:57 PM   #38
radix
radix's Avatar
403
892
Drives: -
No... there are 8 line segments in the puzzle. That *is* the point to the puzzle. You've been tricked.
      02-12-2009, 09:59 PM   #39
oldaccount
oldaccount's Avatar
171
2,455
Drives: Car
if thats the case then this game was designed for retards.
      02-12-2009, 10:00 PM   #40
Razzy
Razzy's Avatar
265
509
Drives: N/A
OMG i wanna sex you.
      02-12-2009, 10:17 PM   #41
aut0sh0cker
meh
125
1,752
**Please note: An intersection between two elements (lines, arrays, etc) is defined as the two element having one or more components in common. A point constitutes an element in my case:
this works in the same way that a parabola with equation y=x^2 intersects the x axis at x=0
      02-12-2009, 10:18 PM   #42
radix
radix's Avatar
403
892
Drives: -
Sorry for the late edit...and forget wiki anything...
Straight from Webster:
Main Entry: 1seg·ment
Pronunciation: \ˈseg-mənt\
Function: noun
Etymology: Latin segmentum, from secare to cut — more at saw
Date: 1570
1: a portion cut off from a geometric figure by one or more points, lines, or planes: as a: the area of a circle bounded by a chord and an arc of that circle b: the part of a sphere cut off by a plane or included between two parallel planes c: the finite part of a line between two points in the line
2 a: a separate piece of something : bit , fragment <chop the stalks into short segments> b: one of the constituent parts into which a body, entity, or quantity is divided or marked off by or as if by natural boundaries <all segments of the population agree>
Sigh... the addition sign was merely a demonstrion. The point is this, line segments end at endpoints, if the line continues, its not an endpoint. You can divide a line segment into further line segments if you like, but the mere fact that one line intesects another doesn't compel you to. BTW, Webster's is probably not the best reference for geometrical definitions.
      02-12-2009, 10:29 PM   #43
BrianDesigns
10
Drives: Legs
who came up with the terminologies in the task? a continuous line has the equation y=mx+b and is straight, rendering this number impossible.
      02-12-2009, 10:44 PM   #44
aut0sh0cker
meh
125
1,752
+100000 he should have called it a "curve"
