02-27-2025, 07:10 AM | #23 | |
![]() ![]() ![]() ![]() 379
Rep 763
No, at most I would swap two front wheels and two back wheels (staggered setup) - I am not that young anymore and I don't work on my vehicles to change oil and stuff - there is an indie and dealers for that. Last week my wife's SUV had a flat and I got there before Geico but unfortunately I did not have any good jack (except the widow maker from my vehicle). I used that carefully and changed her tire (I had a spare for her car). That got me thinking that it would be good to have a proper jack that I could use both in my home garage and throw in the back of the car for emergencies. Therefore I was thinking of Aluminum Floor Jacks - the lightest one that I could get away with. Unlike many on this forum, I don't routinely work on my car so the Jack would be used perhaps twice a year in my garage to rotate tires with the help of jack stands. I looked at the big Daytona Jack but it's an overkill for my situation, takes up space and will offer no portability. Still undecided ![]() I saw this image in one of the reviews on HF website. The big, long reach Daytona jacks are on the top and I am leaning towards the blue Aluminum 3 ton Pittsburgh Jack in the middle. Its actually a bit more expensive than the Daytona long reach but better suited for my limited garage space and perhaps more portable? ![]() Last edited by starlights; 02-27-2025 at 07:17 AM.. |
02-27-2025, 08:03 AM | #24 |
![]() ![]() ![]() ![]() 622
Rep 977
For the X5, you want that nice green one on the top left for sure. I have that middle green one (in silver) and it sucks, it is still heavy, and can't do half of what the newer one does. I'm going to put it up for sale locally.
I also have that really small aluminum one in the bottom, Hugh Jackman jr, and it cant do anything. It isn't rated for the X5, and can't get it high enough for a jack stand, I tried. I couldn't even use it to support the subframe, had to use that other one. Story time I was leaving home depot the other day and there was a gentleman fully underneath his dodge neon fixing something in the parking lot with only the scissor jack. It was hard to just drive away. A friend of mine had a neglected Porsche 944 turbo back in the day, really cool car, we lifted the back left corner to change the tire with the factory scissor jack, and the threads in the hole for the rod absolutely blew out and the car fell like a ton of bricks. It was scary as hell, and we were away from the car behind it. Last edited by B58 parts; 02-27-2025 at 08:14 AM.. |
02-27-2025, 08:46 AM | #25 |
![]() ![]() ![]() ![]() 1961
Rep 604
No kidding. I have a friend who was under a minivan banging on the starter when the vehicle came down on him. Really did a number on him. I prefer my Raceramps when possible. If I use a jack, I don't get under the vehicle until the heavy duty jack stands are in position and, if possible, I leave the jack in place too.
I also have access to a drive-on lift, but not really that helpful for tire rotation. Or even brakes. Great for setting up pinion angles and adjustable panhard bars, with adjustable control arms. because it sits at ride height.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Premium Pkg|Luxury Seating|M668 w/ DSW06+
02-27-2025, 08:54 AM | #26 |
![]() ![]() ![]() ![]() 20297
Rep 20,261
OP, my advice. Somewhere you can find the G05 X5 suspension travel in inches. You can measure from the ground to the bottom of the differential. You can find out the max lift height of the aluminum jack you are considering buying. Subtract the diff hight from the jack lifting height. Then compare that number to the roughly half the suspension travel of the X5. If the delta between the diff height and jack Mac lift is more than 1/2 the suspension travel, the jack will lift the tires off the ground.
The aluminum jack has more than enough lifting power to raise one end of the X5 at a time. To rotate your tires from left-to-right, lift at the diff and put jack stands under the plastic lifting blocks on the side sills of the chassis. You can then safely swap with wheels. The same goes for the front end. Also, get a 1/2-inch drive electric impact gun to remove the wheel bolts. A decent gun is a around $150 and greatly eases the operation of removing wheels. |
02-27-2025, 08:57 AM | #27 | |
![]() ![]() 1255
Rep 2,965
Drives: Anything
I would not bother with rotating staggered tires. I never rotate my staggered tires in over 20 years of owning cars that have them. Just buy the set that get worn out and be done. Do some research regarding reversing a tire rotation that's already set in it's directional rotation orientation. Some tires are directional as well, which can't be rotated side to side without dismounting them from the wheels.
02-27-2025, 09:01 AM | #28 | |
![]() ![]() 2161
Rep 1,996
(Years ago I needed tires -- for my Mustang GT -- and stopped at an indy tire shop. The shop was busy all service bays occupied but the owner used 4 (!) floor jacks to lift the car and got all 4 tires off the ground.) An even better solution -- especially if you do other work on your vehicles -- is to get a portable hydraulic vehicle lift one that is spec'd to lift your heaviest vehicle and one that can lift the vehicles by their body lift points or by the tires/wheels. If you have to limit yourself to one style or the other of course one that can lift the vehicles by the body lift points is the one size fits all solution. |
02-27-2025, 12:20 PM | #29 | |
Rep 604
Don't forget these: https://www.amazon.com/dp/B08LR7R2P8...d_asin_title_1
02-27-2025, 01:28 PM | #30 | |
![]() 4509
Rep 3,471
02-27-2025, 01:31 PM | #31 | |
![]() 4509
Rep 3,471
02-27-2025, 02:36 PM | #32 | |
Rep 20,261
I've always rotated tires on my BMWs because I DIY and I have a lift. |
02-27-2025, 03:18 PM | #33 | |
![]() ![]() 1190
Rep 2,111
It just died on me in December and I went out and bought a Harbor Freight Daytona low profile. I won't be alive in 30 years (or at least not changing my own wheels). |
02-27-2025, 07:15 PM | #34 | |
![]() 4509
Rep 3,471
It was funny. She was also mortified that sports car tires last 15k miles sometimes. I think she's gonna be a Corolla girl for life. |
Efthreeoh20297.00 |
02-27-2025, 08:08 PM | #35 |
![]() ![]() ![]() ![]() ![]() 297
Rep 609
What died? The hydraulics can be rebuilt.
02-27-2025, 08:54 PM | #36 | |
Rep 20,261
02-28-2025, 06:50 AM | #37 |
Rep 763
Thanks for all the responses! I kind of agree with non requirement for staggered tire rotation. I check the tires routinely and so far after 5K they barely show any wear and are wearing uniformly (using the tread measuring tool).
So if I ditch Tire Rotation or get them done at the time of oil change then my requirement changes to get a safe (relative to Scissor jacks) portable jack that I can use outside of the house - the search begins again ![]() Any suggestions? Not looking for a tank, only a safe and robust jack that can be used on the road to lift one wheel as required. EDIT - I may catch a lot of Flac for suggesting this but any thoughts on a bottle jack with built in locking stand for occasional (no more than 2-3 lifts per year or less) such as this for on road and in garage use? https://www.amazon.com/Powerbuilt-62.../dp/B00GJJZ5NI EDIT-2 - Here is another strange looking one made by CAT and weighs under 25lbs - https://www.amazon.com/Wheelie-Off-R...dp/B0DK4PFRH3/ Last edited by starlights; 02-28-2025 at 08:05 AM.. |
02-28-2025, 07:19 AM | #38 |
![]() ![]() 1190
Rep 2,111
02-28-2025, 06:44 PM | #39 | |
![]() 419
Rep 153
If the wheels have to come off, etc.. I use standard jack stands with the Berger adapters to not damage the jack points, or two jacks with the Berger adapters if I am not working under the car. Better safe than sorry. I love pancakes but not enough to want to become one myself! So many horror stories of cars falling onto people because they used only a scissor jack or something while working under the car. That's just crazy. Oh, and uhh don't wear flip flops while working under the car! ![]() |
03-18-2025, 08:01 AM | #40 |
Rep 763
So after a lot of consideration, and the fact that my primary requirement was to have a relatively more robust jack for travel than the scissor jacks I decided to go with a portable CAT off-road unit. Ordered it from Autozone for under $100 (after their $20 online coupon).
Costco takes care of our tire rotations for free and I don't work on wheels or brakes in my garage so the key feature that we required was portability for long distance travel (we have a spare wheel for both cars). This unit weighs around 25 lbs and is compact enough to be thrown in the trunk. https://www.autozone.com/engine-and-...cat+floor+jack Appreciate all the responses and valuable insights from everyone. Thank you!! |
