12-08-2024, 03:51 PM | #23 | |
257
Rep 66
Drives: Phytonic blue 550e
Or if you cannot be bothered, ask your bmw to 'activate maintain battery charge' and it will give you the menu on screen. Then save it as a shortcut if, like me, you will use it a lot. Unlike others who drive in sport mode all the time |
12-08-2024, 07:34 PM | #24 | |
568
Rep 180
2021 M550
SkykingUSA4489.00 kaotiko241.50 |
12-08-2024, 07:38 PM | #25 |
915
Rep 234
I pick mine up on Friday so I’ll start experimenting w/ it but may not be until after the holidays when I actually have more free weekends to just go for drives and really see what options are.
12-09-2024, 07:49 AM | #26 | |
(OO=[][]=OO)
1016
Rep 235
(OO=[][]=OO)
SkykingUSA4489.00 |
12-09-2024, 12:01 PM | #27 |
643
Rep 202
I wish they had a battery control mode so the ICE could recharge the battery to a certain point.
SkykingUSA4489.00 |
12-09-2024, 12:36 PM | #28 |
33
Rep 16
So every time I turn on the car, i have to activate this? Seems kind of crazy, no? Shouldn't this just be a setting that once you turn it off, it's off, until you want it back on?
Either way, I've done this, and the battery still depletes, any idea why? |
SkykingUSA4489.00 |
12-09-2024, 12:55 PM | #29 |
257
Rep 66
You activated 'maintain battery charge' and your battery charge still goes down? Something is wrong.
It has to be set for one or the other and likely the majority want to start in battery mode so that was preferred. I agree the last setting should be saved though, but activating it with a couple of screen touches when required is no big deal really. But obviously it is if it does not work and BMW need to fix it. What a pain. |
SkykingUSA4489.00 |
12-09-2024, 01:08 PM | #30 |
33
Rep 16
Yes, i hit 'activate once' and it activates, but then goes off by itself while driving. As far as I'm concerned, when i do that, the battery should not drain at all while driving, but it still does. If you activate it and leave it on that screen, you'll see when it goes on and off by itself. I also had 25km of range on my battery friday night when i got home, didn't drive the car saturday, then sunday morning turned it on and had 14km of range. Love this battery. Feel like I got totally ROBBED on this car.
12-09-2024, 01:37 PM | #31 | |
(OO=[][]=OO)
1016
Rep 235
(OO=[][]=OO)
SkykingUSA4489.00 |
12-09-2024, 03:53 PM | #32 | |
257
Rep 66
Obviously the battery spec is different from the European models going by reported range but that is strange given it is likely the same gen 5 phev battery and similar warranty. It was 1c / 34f here at the weekend and I charged to 100% for a change to check the range. I had a 40m / 65km run and did it on battery at 60/65mph with a little bit to spare. Good luck getting it checked out, hopefully just a software issue. |
12-09-2024, 05:31 PM | #33 | |
568
Rep 180
2021 M550
12-09-2024, 08:02 PM | #34 | |
257
Rep 66
Like many things BMW, it makes no sense. |
PeterC4568.00 SkykingUSA4489.00 |
12-09-2024, 08:57 PM | #35 | |
568
Rep 180
I've read various explanations for why this is different, including useful life/warranty expectations.
2021 M550
SkykingUSA4489.00 Dragonfly Trumpeter256.50 |
12-10-2024, 08:33 AM | #36 |
33
Rep 16
I figured out why it deactivates on its own. If you touch the paddles at all, it'll deactivate after you activate it, which again, makes absolutely no sense. I've complained to BMW Canada about this, seems like they could care less. I don't see why they'd sell a hybrid that does nothing, and charge an extra 15k for it. So discouraging knowing that the old 550i was a beast!
SkykingUSA4489.00 |
12-10-2024, 08:38 AM | #37 |
257
Rep 66
If you touch the paddles you are effectively changing the driving mode. If you do not want to drive it as a typical phev, stick it in sport all of the time.
SkykingUSA4489.00 |
12-10-2024, 10:24 AM | #38 |
33
Rep 16
But then what's the point of the battery if it still drains the second you touch a paddle? Pointless.
SkykingUSA4489.00 |
12-10-2024, 10:35 AM | #39 | |
257
Rep 66
Or if you want it like your old 550i, drive it in sport. Even the M5 is hybrid now. |
12-10-2024, 10:10 PM | #40 |
568
Rep 180
So the question for you is: In your experience, does the depletion of the battery adversely affect horsepower, or just fuel economy?
2021 M550
12-11-2024, 07:06 AM | #41 | |
257
Rep 66
If there were extreme circumstances where you could use max power for any length of time it could be a phev problem, for sure. But with near 500hp, I hate to think where you would end up in half a minute. Sport mode does a great job of managing power and charge level and the car is a beast then if required. This is my 3rd bmw phev because they suit my requirements, fortunately. A lot of local battery running and a regular 400+ mile return day trip with time restraints. The 60 litre tank covers that on it's own easily so not even a fuel stop, never mind a charge. I maintain battery charge and only use ice on these trips and economy is great at around 8m / litre anyway. However, I do charge regularly and use it as designed. Phevs do not suit everyone but are well manageable once you get used to them and appreciate what you are driving. And we all have so few options now. If you want an ice only 5 in the UK for example, you have a 520i pea shooter. I am not sure any car ticks all the boxes. |
12-11-2024, 08:25 AM | #42 | |
3388
Rep 942
Drives: 2025 BMW 540i XDrive
Dragonfly Trumpeter256.50 SkykingUSA4489.00 |
12-11-2024, 09:10 AM | #43 | |
257
Rep 66
But if BMW can sell a 520i here now, why would they not be 'allowed' to sell a 6cyl 540i? And it is still only 2024. Your point re going elsewhere if the 540 was not available simply emphasises the bmw marketing shambles. The UK sales of ice cars may be in high demand in 5 years time |
12-11-2024, 09:26 AM | #44 |
33
Rep 16
Why is it if you drive it in electric mode, the fuel tank still depletes, on basic city driving, never going more than 60km/hr? Also, was on the highway today, all electric abilities were enabled, I got to 135km/hr to pass someone and then the car wouldn't go any faster, and the ICE wouldn't kick in. Any idea why? Still say this car is a POS. Totally regret it.
SkykingUSA4489.00 |
