08-20-2024, 12:49 PM | #23 | |
18660
Rep 19,431
Now looking at the hole in the windshield, to me it looks like the caliper dropped straight down from some significant height. The rim of hole in the glass points downward, not rearward. Additionally the caliper would be traveling in the same forward motion as the Hyundai and at nearly the same speed, so the force on the windshield would be only 10, maybe 15, miles per hour less than the assumed highway speed. All motion is broken into X, Y, and Z axis (vectors). I just can't see anyway that caliper ripped from a truck in front of the Hyundai and went through the windshield. Last edited by Efthreeoh; 08-22-2024 at 12:16 AM.. |
M5Rick66283.50 TheMidnightNarwhal2767.00 |
08-20-2024, 01:08 PM | #24 |
66284
Rep 21,441
When I get the right moment (recovering from illness) to change my rear pads I'll make sure I'll use the calliper bolts supplied with the new pads with the fresh loctite bands on them and not to re-use the old ones.
Efthreeoh18659.50 |
08-20-2024, 01:13 PM | #25 |
The Seeker
14925
Rep 3,679
It's in the beginning of the video.
08-20-2024, 01:27 PM | #27 |
227
Rep 120
My point, loctite or not, was moreso just to torque to spec. It's crazy to me how many people insist they don't need to.
2024 M3Cx - Isle of Man Green, Tartufo, CF Exterior & Interior
08-20-2024, 01:28 PM | #28 |
227
Rep 120
Ah, got it, thanks. I never watch videos on those news sites because I'd rather read than sit through 2-3 ads as most of them have.
Either way, I stand by my statement: torque your calipers to spec.
08-20-2024, 02:47 PM | #29 |
2734
Rep 2,128
I'm gonna disagree. Don't torque to spec on caliper bolts. Torque over spec. Not by a hundred extra ft lbs, but by a little bit. Why? Because what we are really after with torque is clamping via bolt tension. A bolt that's 35 years old and has been on and off 100 times is going to lamp less via bolt tension than a brand new bolt.
I once lost a front caliper bolt that was torqued to spec. The caliper rotated on the other bolt, and smashed into the wheel, scraping against the wheel barrel (which was a VERY effective brake btw). I don't recommend having that happen to you. A little extra torque, and a new bolt when your old one feels "sloppy" makes life a whole lot better. |
08-20-2024, 02:57 PM | #30 | |
18660
Rep 19,431
08-20-2024, 03:03 PM | #31 |
The Seeker
14925
Rep 3,679
Holy hell! I can't even imagine how this would happen.
08-20-2024, 03:10 PM | #32 |
18660
Rep 19,431
///MPhatic14925.00 |
08-20-2024, 03:52 PM | #33 | |
2734
Rep 2,128
08-20-2024, 03:58 PM | #34 |
2734
Rep 2,128
What do you mean? The top bolt came out, and the caliper (and bracket) rotated around the (still bolted) lower bolt when I applied the brakes. It almost immediately locked up that wheel (because the caliper was quite literally jammed against the wheel).
There was no way someone would "not notice" it. It locked up a front wheel and dragged the car to the side abruptly. I was able to drive it a few hundred feet with the steering wheel pointed the other way to get out of the road. We used a large hammer to knock the caliper back into place. It was super sketchy, and the car gods were smiling on me that day. We had just got back down from some spirited mountain driving. We were a couple hundred feet from my buddy's parents house that had enough tools to effect some basic investigation and repair. It was 15 minutes away from disaster with me going over the edge of a mountain. |
08-20-2024, 04:58 PM | #35 | |
2767
Rep 6,374
But for sure, guide pins torque are usually much lower. I remember my noob mistake once on my first car, I thought the torque spec I had was for the caliper bracket bolts but I was tightening the guide pins... ehehe *snap*. Thankfully the way those guides pins were designed was like a screw into the pin type of design compared to how it is on BMW, so was easy to swap and got part at local store since it was just a generic Hyundai. |
08-20-2024, 07:12 PM | #36 | |
2734
Rep 2,128
But yes, that's fair. Domestics like to use a hell of a lot of torque. |
08-20-2024, 09:12 PM | #37 | |
18660
Rep 19,431
I'm not saying you specifically, but most people don't understand how fasteners work and how threads work. |
M5Rick66283.50 |
08-20-2024, 09:44 PM | #39 |
2734
Rep 2,128
Just for funsies, gonna throw out the concept of running torque, and how I've never seen an automaker specify a value over running torque. One would think in automotive applications where you've got variation due to corrosion, penetrating fluids, loctite, etc it would be the ideal place to have a spec for value over running torque...
08-21-2024, 09:36 AM | #40 | ||
#buildnotbought
12488
Rep 5,247
45lbs-ft for a 12mm or 14mm bolt is an extremely low value. But the caliper bolts aren't stretch bolts, like the ones used mostly on the subframes and underside tension bars and plates. They are allowed to be used again. Quote:
However, the caliper didnt jam against the rim. With normal driving, it was pulled into the normal position. (this is called a skating force) Before the bolt came out (so when it was loose) I occasionally heard a small rattle. I inspected the car at the side of the road (I was abroad) and thought it migth be something with the ARB (like an ARB link that got some play or so), but couldn't find anything. When the bolt came out I could hear the occasionaly louder clunk (and then knew something was really wrong, but no lockups or so like you describe. I had to ask other people on the roadside to look at my front wheel to see what was happening when I drove the car forewards and in reverse. They immedately saw the caliper move as soon as I changed direction. I had no idea it was the caliper, at the time I was more thinking something wrong with the suspension arms or so. I temporarely fixed it on the roadside by putting a wheel bolt in it (that has the same threadsize) So I can imagine people just driving along with this. The bolt was torqued to spec btw. I mark all bolts with a paintmarker after torquing. The lower one still had the marker (the upper one obviously was gone, but I assume it was marked also ) When replacing the bolts afterwards, I also checked the bolts on the other side and measured the torque to loosen. That was all OK. I guess this stuff just sometimes happen.
BenitoBlanco227.00 M5Rick66283.50 |
08-21-2024, 11:53 AM | #41 | |
18660
Rep 19,431
TheMidnightNarwhal2767.00 M5Rick66283.50 |
08-21-2024, 12:47 PM | #42 | |
2767
Rep 6,374
But yeah that's the thing, you are right on the money, the bolt size is M10. On the E9X M3 for example it's a M12 bolt which that one spec rating is 81ft lbs. Last edited by TheMidnightNarwhal; 08-21-2024 at 12:53 PM.. |
GuidoK12487.50 |
08-21-2024, 03:26 PM | #43 | |
#buildnotbought
12488
Rep 5,247
These have indeed lower torque rating (indeed roughly 47lbs-ft) The guide pins indeed need far less torque. but there is a difference in function between the guide pins and the bracket bolts. The guide pins don't get to endure the rotational braking force. Neither does the caliper. The brake pads (who get the rotational braking force) transfer that force to the caliper brackets and then into the hub. (For a floating caliper that is) But for a rear caliperbracket I can imagine it's of far less importance that it's torqued to a very high value. Braking forces on the rear are almost negligible compared to the front (if I had to make an estimate...maybe 25% tops of the front braking force?). I'm always amaized for example after driving an alpine pass how hot the front brakes get and how cool the rear brakes stay. (and I even run slightly more rear brake bias than stock)
M5Rick66283.50 |
08-21-2024, 11:40 PM | #44 |
18660
Rep 19,431
Seriously, do I need do go get my Bentley manual or look up the bolt sizes on realoem when I write a fucking post. Who gives a shit if the rear caliper mounting bolts are M10 or M12 or even M14? The point I was making is (a) most noob DIY'ers way over-torque brake hardware because they think tighter is better, and (b) I was indicating the torque values are far less than noobs think they are.
But all of this arguing is pointless because the caliper that killed the poor young woman didn't come from the wheel of the truck after breaking away from the hub, it reportedly fell out of the bed as part of an unsecured load. No one has thought of the possibility the truck didn't have a tailgate and the dumbass driving the truck didn't think his unsecured caliper could fall off the back of his truck and kill some one. |
