06-19-2024, 11:35 AM | #23 |
Starfleet Command
408
Rep 812
From App. is this normal?
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels, |
SkykingUSA3348.50 |
06-19-2024, 12:51 PM | #24 |
4659
Rep 1,283
On a spirited drive with other M cars, I got 3.3mi/kWh. That was with no A/C. High speed freeway driving drops down to 2.9 mi/kWh.
deutsch1005234.00 SkykingUSA3348.50 |
06-19-2024, 02:46 PM | #25 | |
Starfleet Command
408
Rep 812
On the side, I drive a 911 GTS and the M60 is so much faster.
22" 747M wheels, |
06-19-2024, 02:49 PM | #26 |
4659
Rep 1,283
Yes, but your efficiency will improve with time. Commuting to work with traffic, and maybe having some fun on weekends. I use the boost paddle on rare occasions.
SkykingUSA3348.50 |
06-19-2024, 11:03 PM | #27 |
4659
Rep 1,283
I drove 13 miles out to a remote area to try launch control. Warm out 76 degrees. I got 3.9mi/kWh. Then I did launch control and drove back getting 3.0mi/kWh.
The A/C was on. |
deutsch1005234.00 |
06-21-2024, 06:30 AM | #28 |
1226
Rep 8,034
Mine is starting to improve now the better weather is coming and this morning I had it on charge but didn’t make it to 100%, in any case it was pretty decent at 273 miles with 95%SOC.
06-22-2024, 01:21 AM | #29 |
4650
Rep 1,138
Drives: 24 BMW i5 M60
Sorry, I’ve been traveling this week and just getting back to this. Probably the other replies have addressed this - my original point is significant drops in efficiency are much more likely due to driving faster/heavier acceleration than just A/C on or off.
06-22-2024, 11:26 AM | #30 | |
174
Rep 523
This morning, I decided to try the Electrify America Las Vegas South Premium Outlets. There are only 6 CCS chargers there and 2 were available when I arrived at 6:15 a.m. This time I started with 48% available charge and charged for 28 minutes which got me to 92% and an indicated range of 331 miles. Should be more than enough for the return to L.A. tomorrow. |
RichardInCA4650.00 Scrapula4659.00 deutsch1005234.00 pixelcort45.00 SkykingUSA3348.50 Sisyrx274.00 F10_Freq234.00 |
06-22-2024, 10:54 PM | #31 |
3349
Rep 1,127
Drives: 2024 i5 eDrive40
Sounds great so far. Hopefully your return trip will be as successful.
06-29-2024, 02:37 AM | #32 |
234
Rep 65
So my commute experiment doesn’t look as good for my i5. I had to start over with a 100% charge last Saturday. Began with a 336mi estimated range this time. After a week of daily commuting (~36mi round trip) and a few small trips I’ve traveled 219 miles. I’m now at 16% left with 53 mi of estimated range left. If I pushed to the end I’d guess I would clock only 260mi or so. : (
Here are my details: eDrive40 with 20” wheels, Efficient mode and B mode most of the time, highway assist used for about 70% of stop and go (Los Angeles) highway driving…rarely got over 70 mph. A/C was set to 69 auto, ventilated seats on auto, stereo bumping, outside temp around 75-90 (but garaged during day so it wasn’t too hot when leaving work each evening). Looks like my efficiency was 3.3 kw/mi. In other modes I’ve been seeing 3.7kw/mi. |
06-29-2024, 10:35 AM | #33 | |
4650
Rep 1,138
Also *really* bad stop and go traffic doesn’t help either as you drain power to keep the car stationary with AC, entertainment etc. Probably not a huge drain but I’ll be it could knock 0.2 mi/kWh off your efficiency or so. |
06-29-2024, 05:19 PM | #34 |
234
Rep 65
Thanks. Thants exactly what I want to gauge, what the initial estimates translates to in reality. In my F10 a full tank will say 400+ miles but it was soon apparent that 280 mi was what I should expect.
I’m definitely going to keep experimenting. Ultimately it was a week of driving on single charge, so that’s more than enough for my daily needs. |
07-27-2024, 04:36 AM | #35 | |
3349
Rep 1,127
07-27-2024, 04:50 AM | #36 |
3349
Rep 1,127
Here is an efficiency number I may never see again. LOL I started the trip meter near the top of a long sloping hill and took this photo shortly after it leveled off at the bottom (as you can see, only a 2.6 mile trip). Sigh, if only we could CONSTANTLY drive downhill.
Actually, my most common regular trip is about 10 miles each way (from home to the tennis courts and back) for a total of 20 miles. Earlier this week, using D driving mode with minimum regeneration I got 3.1 mi/kWh one way and 4.4 mi/kWh the other. That's a round-trip average of about 3.75 mi/kWh. With a useable battery capacity of 81.2 kWh that's a maximum range of about 305 miles. I suspect it will even be better for longer trips that don't have so many hills in them. I should be able to test that this fall when I drive out to the Palm Springs area from the Los Angeles area and back. I think I'm getting better efficiency by using the D mode with minimum regeneration than I was when I was using B mode. I'll probably do another comparison next week with both modes and compare. By the way, temperatures have been in the 90s Fahrenheit here during these trips.
07-27-2024, 01:20 PM | #37 |
4659
Rep 1,283
RichardInCA4650.00 SkykingUSA3348.50 |
07-28-2024, 01:49 AM | #38 |
3349
Rep 1,127
Good to know, and glad you had a fun time. Thanks for sharing.
08-01-2024, 02:17 PM | #40 |
3349
Rep 1,127
This week, I did a comparison of driving in B mode and D mode again (with minimum regen). Temps were in the 80s F on both days, and each day I drove my typical 20 mile round trip from home to the tennis courts and back (took the same route each time).
For both trips I got the same efficiency: 4.0 mi/kWh. Extrapolated out that's about 325 miles on a full charge. I'm happy with that.
08-01-2024, 07:52 PM | #41 |
4650
Rep 1,138
OK - I’m throwing this down as a challenge to my fellow M60’rs - anyone got a better number for July?
SkykingUSA3348.50 |
08-01-2024, 08:05 PM | #42 | |
5234
Rep 2,886
Driving in Efficiency does give a wee more range. |
SkykingUSA3348.50 |
08-01-2024, 10:58 PM | #43 |
4659
Rep 1,283
Not that great this month. But, I drove 0% in efficient mode.
SkykingUSA3348.50 |
08-02-2024, 03:56 AM | #44 |
3349
Rep 1,127
Very well done! You even beat my single-motor eDrive40 in July.
Scrapula4659.00 RichardInCA4650.00 |
