06-06-2024, 06:34 AM | #23 |
2361
Rep 679
Drives: 2025 BMW 540i XDrive
In the Build my own under options if they selected mobility kit, there is an exclamation point. If you hover over it it says Mobility kit deletes space saver spare tire. If you did not select it, you would have a raised center portion of the trunk floor, with a storage space, and the spare tire and jack. If you raise that up, then you see the view you have.
SkykingUSA3341.00 |
06-06-2024, 06:40 AM | #24 | |
2361
Rep 679
OriginalFake576.50 SkykingUSA3341.00 |
06-06-2024, 08:59 AM | #25 |
57
Rep 56
"Get the peace of mind of knowing you can keep driving, even after sustaining tire damage. A powerful compressor and special tire sealant for minor mishaps will ensure that you stay mobile until the nearest BMW Center. Available with non run-flat tires only."
This is the description from the US 2024 540 build site. It does not say removes spare tire kit. I have the spare tire kit in my 2018. Definitely lose a lot of trunk depth, cannot put a 48qt cooler or some luggage vertical. In the past the $150 spare tire kit was around $1000 if ordered parts individually from the parts Dept. |
SkykingUSA3341.00 |
