      12-12-2023, 09:08 PM   #23
trivalent
trivalent's Avatar
210
77
Drives: 2024 BMW i5 eDrive40 M Sport
Originally Posted by anujpuri85 View Post
If you don’t mind my asking, how did you remove the mirror and where did you tap in with the wiretap? I just got my i5 and am looking to do this as well
Hello. You remove only the base around the mirror. The entire procedure should be quite similar to what this video demonstrates:
alewifebp566.50
SkykingUSA4734.50
      12-12-2023, 09:49 PM   #24
anujpuri85
Drives: 2024 BMW i5
Thank you!
Oh you’re awesome, thank you! (And sorry for the double posting across the two sites) Quick question: I’ve never had a BMW, but I’ve done a wiretap in other cars and a few have had issues when unplugging the mirror wire, such as settings resetting or airbags deactivating. Are there any gotchyas here?
      12-12-2023, 09:56 PM   #25
trivalent
trivalent's Avatar
210
77
You are quite welcome. The cross-post was fine, too.
I cannot advise on wiring risks. All I can report is that in both my former i4 and my current i5, the harness that can be used for the MirrorTap pins does not need to be unplugged or removed. Also, if you are not sure which sockets are ground, switched, etc., use a multimeter to test them.
      12-12-2023, 10:02 PM   #26
anujpuri85
Drives: 2024 BMW i5
Great, that’s enough of a green light for me lol. Thanks again!!
      12-12-2023, 10:10 PM   #27
trivalent
trivalent's Avatar
210
77
Okay! Be safe out there.
      12-23-2023, 03:11 PM   #28
MikeElmendorf
1601
843
Drives: 2022 BMW X5/2024 i5 M60
So to close the loop on the Blendmount issue: The bracket I had from my M550 works just fine in my i5 M60. Not sure why Blendmount thinks it won't and designing one is impossible. Installed it today and its just as it should be.
It fits tight and fine. It is a little lower than it was in the M550, but that's ok because there it was very close to the garage door buttons.
Just have to get my dealer to move the tap cord so it pops on the passenger side instead of driver (I've had the V1 on the windshield with suction powered by the tap for now.)
Appreciate 4
alewifebp566.50
SkykingUSA4734.50
trivalent210.00
      12-24-2023, 01:16 AM   #29
alewifebp
567
285
Drives: 2024 i5 M60
2024 i5 M60  [0.00]
Great to hear. I've been meaning to try the mount from my X5 to see how it works.
SkykingUSA4734.50
      12-24-2023, 07:35 PM   #30
scottjays
Starfleet Command
scottjays's Avatar
428
821
Drives: 2020 X5 M50i
I removed my blend mount from my X5 I installed it in the i5 don’t know exactly how it fits but it’s seems secure enough
SkykingUSA4734.50
      09-29-2024, 08:58 AM   #31
vallejojo
27
10
Drives: i5 M60
2024 BMW I5 M60  [0.00]
Originally Posted by MikeElmendorf View Post
Well, I got the same answer from Blendmount. I was hoping you just got someone who was having a bad day.
I find it hard to believe something can’t be engineered to work.
In the meantime, I ordered this from Amazon in the hope it might work: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I’ll probably just have my guy install the mirror tap so that’s in and I can mount once a bracket is found that will work. It has to be just a matter of time. Perhaps someone here will figure it out. We put a man on the moon, for crying out loud!
But did we actually put a man on the moon?
SkykingUSA4734.50
