      05-01-2023, 07:38 PM   #23
skyline408
skyline408's Avatar
1637
1,265
Drives: 2023 G80 M3 2022 F95 X5M
Originally Posted by Eljefe25 View Post
Good point but the man the amount of brake dust is ridiculous. I feel like after my wheels are clean, driving 2 miles and the amount of brake dust you see is crazy.
I’ve never experienced this amount of brake dust before.
The only good thing is it’s motivated me to probably start washing my car myself which should give me more control over the process.
On every M car i've ever owned, the brake dust is part of life!
      05-01-2023, 09:15 PM   #24
Housekeeping
604
458
Drives: 2013 BMW M5
Get brake pads that dust less, makes a huge difference.
KevinGS4422.50
NickyC19630.00
      05-01-2023, 09:19 PM   #25
Jrock645
92
105
Drives: BMW X3
Originally Posted by Throatpunch View Post
Sonax wheel cleaner then a pressure washer.
Ceramic coat them and u never have to hand clean
I second this. Doesn’t hurt to have some brushes to get into the crevices but this should blow off most of it. Poorboys has a good wheel cleaner too.
Polish Angel has a good wheel coating that is quick and easy to work with.
      05-07-2023, 04:48 PM   #26
pasta
pasta's Avatar
78
74
Drives: F82 M4
Does the Wolly Wormit actually fit in the barrels without just smashing into the brake pad shield? I haven’t found a brush thin enough to get in there and just tried the bristle type one without much success.
F82 ///M4 | F30 320i | Ducati 959 Panigale
SOLD: E92 335i | E30 325i
      05-08-2023, 07:25 PM   #27
Ralph III
128
123
Drives: 2018 BMW 650i Gran Coupe
I've been using Turtle Waxes Hybrid Wheel Cleaner & Tire Prep (HyperFoam) on our 650i. It's safe, has iron remover, and leaves a protective finish.
Most of the time I just spray it on and then rinse it off, being that is all that is really necessary. You can see all of the grime/dust just dissolve right off. It's meant for both the rims and tires and leaves the tires so clean, that a tire dressing isn't necessary.
Anyhow, I managed a detail business for 14 years and this is some of the best stuff that I've ever used. It stinks a little though due to the iron remover but it's a great product.
Ralph
      05-08-2023, 10:48 PM   #28
Nick8915
58
50
Drives: 2023 X3 M40i
Ralph
Any concerns with the Turtle Wax Hybrid Wheel cleaner on ceramic coated gloss black 718M wheels?
fraschusa224.00
      05-09-2023, 05:57 AM   #29
fraschusa
fraschusa's Avatar
224
65
Drives: 2023 M5 Comp
Brake dust is insanse on my car though and my wheels are ceramic coated.
I went through a touch less laser wash recently but they did not clean the wheels well.
Think I’m gonna start washjng my car by hand. I’ve been doing a lot of research and the process does not seem hard.
Does seem like you need some agitation to get the brake dust off the wheels though.
I wash the wheels before I go to the car wash, that seems to do the trick. I have also sprayed the wheels when you are waiting in line for the car wash but it doesn't do a great job but it's better than just the car wash option.
      05-15-2023, 02:14 PM   #30
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3129
2,784
Drives: CT5V-Blackwing
Originally Posted by allinon72 View Post
- You clean them frequently enough that the dust does not build up to a level that is hard to remove.
For me, this is the big secret.
Originally Posted by skyline408 View Post
I have ceramic coated my wheels, and no - I can't just hose off the wheels with no scrubbing to get them clean.
There is no magic solution and no amount or any kind of ceramic will clean the wheels from just water spray without agitation.
This has been my experience as well. Those who think they can just spray and rinse either do not get the wheels very clean, or they don't own a BMW with high performance brakes.
Absolutely. Porsche is nearly as bad.
But you lose in braking performance.
I find that it depends on the car - some have larger shields than others. I guess it also depends on the wheel size...
FWIW, I try to wash the wheels every time I wash the car, which is weekly. That's the only true solution.
For the 826 wheels on my M4, which are very difficult to clean, I bought a grout sponge and cut it in half. It works well, along with Griot's wheel cleaner and soapy water.
Current inventory:
F22 M240ix (wifey)
G29 Supra with three pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
      05-19-2023, 10:11 PM   #31
Ralph III
128
123
Hello Nick and sorry for being slow to reply. That product only says it's safe for "chrome, steel and aluminum". They have another product called Hybrid Solutions Pro All Wheel Cleaner + Iron Remover that says it is safe for painted surfaces and clear coats. So, I recommend using that on your painted rims.
God Bless,
Ralph
      05-20-2023, 11:02 PM   #32
Tony_M3
Tony_M3's Avatar
287
174
Drives: 2023 G80 6MT
Okay so I started doing the following in my existing wheel cleaning process and am noticing better results:
  • Bought a dedicated wheel mitt and stopped using the boars hair brush for everything except the lugs.
  • Switched out the whooly wormit for a microfiber madness inredibrush. The microfiber madness brush seems to glide in smoother and I can get it behind most of the front calipers.
  • Started spraying the wheels with foam cannon filled with the soap I use for the rest of the car in addition to spraying the wheels with brake buster (which I was previously doing).
I’ll keep everyone posted to see how this process holds up over time. I’m considering getting my wheels ceramic coated but I believe I had that done on my f80 and could barely notice a difference.
      05-21-2023, 07:47 AM   #33
neilybealy
United Kingdom
44
54
Drives: bmw X4
Bilt Hamber’s Auto Wheel. Spray on leave for 5 mins then use wheel mitt and brush to agitate then jet wash off. Simple
      05-22-2023, 04:07 PM   #34
DocL
DocL's Avatar
2157
965
Drives: 2018 M3 Comp 6spd
I’ve never experienced this amount of brake dust before...
Is this your first BMW?
I can remember my mother's 733i and my father's M6 back in the 80s always having terrible brake dust. When it came time for me to replace the pads on my F80 I installed Akebono. Although there is 90% less dust, the wheels are a little dirty but not as bad.
"Education will never be as expensive as ignorance."
      05-22-2023, 06:08 PM   #35
GoRomeo
GoRomeo's Avatar
1337
4,240
Drives: 330i, 135i
2008 BMW 135i  [6.33]
2006 330i  [6.75]
Ever since I replaced my brakes for the AKEBONO ceramic kind the brake dust is a thing of the past. This is for my e90 though. I am thinking of doing the same for my E88 but I just replaced them with regular ones and yes brake dust gets crazy quick.
      05-22-2023, 09:27 PM   #36
NickyC
NickyC's Avatar
19630
11,386
Drives: M4 CS. Former G82, x2 F82, F80
That's really the only true option.
      05-23-2023, 08:13 AM   #37
Artdnj
Artdnj's Avatar
413
734
Drives: 2023 X3 X30i
I always use Sonax and just wanted to say I decontaminated my new X3 and had a little Adams iron remover left over. My daughter has an older 128i with wheels that have baked on brake dust material in some of the curves of her wheels.
Adams made the wheels come out damn near new, unbelievable product, can't believe I never used it before. Her wheels haven't shined like they do now for years.
      05-27-2023, 08:37 PM   #38
evoi19
evoi19's Avatar
1733
17,456
Drives: 2022 G80C
My wheels are ceramic coated and I stopped using a specific wheel cleaner. Too much of a hassle.
I just foam the wheels when washing the car and then after washing the body, I use a separate MF towel to clean the wheels.
spazzz167.00
      05-28-2023, 10:53 PM   #39
dradernh
dradernh's Avatar
4815
3,607
Drives: 2017 M240i
Originally Posted by alexpro45 View Post
I would recommend Sonax Wheel Cleaner Plus. You can get it at amazon. Always follow the manufacturer's instructions and test new products on a small area before applying them to the entire wheel surface. Happy cleaning!
That product worked very well for me when I was running race pads and track wheels. The pads produced quite a bit more dust than do the OEM pads that already produce a lot of dust.
Even with the Sonax product, I needed brushes and some work to return the wheels to looking as good as new. It helped that the wheels were off the car when I cleaned them. These are the brushes I finally settled on: https://www.2addicts.com/forums/show...6&postcount=14.
Now, I live in a condo and just take the car to a detailer.
2017 M240i: 25.9K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; Full PPF
      06-01-2023, 12:22 AM   #40
Score04
244
643
Drives: ‘23 BMW X3 M40i
Originally Posted by snakes1021 View Post
I use chemical guys signature series wheel cleaner and every few months some hydro charge ceramic spray on a microfiber towel after they are clean repels break dust pretty good IMO. Im sure there are other similar sprays from other companies
and wheels brush similar to these
https://www.amazon.com/bzczh-Metal-F...%2C197&sr=8-15
Try Iron X after brake buster:
8/8/22 - Sold 2005 Acura RSX Type-S
9/29/22 - 2023 X3 M40i
      06-01-2023, 03:09 AM   #41
RichF90M5C
RichF90M5C's Avatar
1635
432
Drives: 2023 F90 M5 Competition
I’ve just got some of this and it’s amazing. The multi spoke wheels on my wife’s new 128ti look great, but are a nightmare to clean, but with this stuff I just sprayed it on, jet washed off, and they’re spotless. Didn’t even need to touch them with a sponge.
      06-01-2023, 03:46 AM   #42
neilybealy
United Kingdom
44
54
Drives: bmw X4
Yeh it’s great stuff. If my wheels are really dusty then I’ll still tend to use a mitt etc rather than just jet wash off but I might try that next time
      06-01-2023, 04:50 AM   #43
M5Rick
M5Rick's Avatar
72771
21,823
Drives: M5 F10 DCT Gunmetal
Pressure washer on the wheels or car is a no for older models. On the 343M wheels a smaller bucket with suds and a sponge for the facings then an old long handled wash up brush for behind the spokes and inner rims then water rinse from a watering can.
An occasional wax polish makes them easier to clean.
