01-25-2023, 05:01 PM | #23 |
![]() ![]() ![]() ![]() 17777
Rep 11,713
Drives: 2018 M4 Comp Indv
Sure, just remember, if you have any protection on the car (wax, sealants, coatings) you have you to get it off to get the most out of any coating / sealant. Typically the non-marring non-physical decon steps would be something like:
* If it's really dirty spray off first * Strip wash with an alkaline shampoo like CP Lift or BH Touchless Inspect for any bug guts, tar*, etc that's remaining & remove * Iron remover, then rinse w/ de-i water Optional: if you really really wanna be double sure to remove anything remaining * CP TarX each panel: apply & rinse as you go, ideally with de-i water * Do a final quick shampoo of the whole car just to ensure you've gotten all the decon chemicals off, and then rinse w/ de-i * Dry & do a panel wipe with 50/50 IPA & de-i water That should strip off most protection except multi-year ceramics (but will strip some of them too!) Your paint should sheet water, looking totally "flat", i.e., no beading or hydrophobicity. Any coating you apply will be its most effective at filling in marring and will adhere its best. It's also your best time to apply a 2nd layer after the 1st cures and/or a hydrophobic topper (e.g., Nova Lustre topped with Nove Jet) |
01-25-2023, 06:05 PM | #24 |
Rep 604
* Strip wash with an alkaline shampoo like CP Lift or BH Touchless.
I though Bilt Hamber Touchless was designed not to strip wax, sealants or other LSP products. |
01-25-2023, 08:12 PM | #25 |
![]() 14
Rep 35
I thought nova lustre was meant to hide swirls in my existing multi-year ceramic? Reading about the product I assumed I was going to give a good wash that would leave ceramic in tact then apply NL. Sounds like I am way off base?
01-25-2023, 11:15 PM | #27 | ||
Rep 11,713
Note that neither of them is going to do anything to a resin-based multi-year ceramic assuming it was properly applied. ![]() Quote:
You can try that, and it'll work, but /rant This is where multi-year ceramics make no sense and are a waste of money and kind of a scam IMO. Wheels & exhaust make sense but the rest of the car? not sure why one would do it assuming they understand the details. multi-year ceramics won't protect against marring so if one gets scratches that they want to buff out, now what? They can always buff out just that spot then re-apply but why have a multi-year ceramic then?? ![]() Same with PPF: if it gets dinged up, now what? leave it dinged / dangling? spend the money to replace it? I suppose it's all preferences ... but ... for me, yeah, I don't get it ... though all the damage is annoying, that's for sure. AANNYYyyywwaaaayyyy... /rant If you have a multi-year ceramic, your best bet is to a strip wash (i.e., road film removal, i.e. BH touchless or lift or reset or similar) and then use an APC panel by panel (apply & rinse well & dry) to ensure you've "declogged" it and got it as pristine as you can. Lustre should work to fill in the marring but ... Now your coating is Lustre, not your multi-year ceramic ... which brings us back to why have a multi-year ceramic in the first place. But, forward focus: it's there & you want to hide marring, so try Lustre. With that, you have to remember, coating-to-coating bonding is less sure than coating-to-clear-coat and a multi-year ceramic's whole purpose is to resist things bonding to it which means while Lustre will probably work as advertised, you might have to re-apply in, say, half the normal time, and you might have trouble applying it. Just hard to say.
01-26-2023, 09:39 AM | #28 |
![]() 14
Rep 35
A previous poster mentioned CarPro Essence Plus. It seems to meet my use case and have great reviews on amazon. Sounds like the process would be a decontamination wash, then potential clay bar?, then apply this either by hand or via a RO polisher? Does anyone have experience with this product or something similar?
01-26-2023, 08:57 PM | #29 | |
Rep 11,713
