03-23-2022, 12:56 PM | #23 |
Free Thinker
19787
Rep 7,561
Is there any reason to not use connectors like this instead of wire nuts? I've been mounting new lights outside our doors lately. The wires from the lamps are not solid copper, so it's a pain getting them to work with the romex using wire nuts. It's doable, but a hassle. I'm wondering if this type of connector would work better.
03-23-2022, 01:49 PM | #24 |
Recovering Perfectionist
22170
Rep 1,031
Don't tell the IBEW or the wire nut cabal that I shared this link for UL-approved (residential use) electrical connectors:
https://www.amazon.com/gp/product/B018MGMFDI/ I've used them in all of our ceiling fan electrical boxes, to join stranded wires from the fans/lights to solid copper power wires. You're welcome.....
Currently BMW-less.
DETRoadster11506.00 |
03-23-2022, 04:06 PM | #25 | |
Free Thinker
19787
Rep 7,561
03-23-2022, 04:28 PM | #26 |
2261
Rep 1,360
As long as the wire is captive and insulated I wouldn't stress it.
youll see wago levernuts in panels and whatnot. those are actually more secure than a wirenut. ESPECIALLY with stranded. Wirenuts work best with solid wire thick enough where you can twist the wire up so the wire itself serves as the mechanical connection and the nut is as much insulation as anything. |
03-23-2022, 04:41 PM | #27 |
594
Rep 145
I like to use Marr connectors when joining stranded and solid wire.
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
03-23-2022, 04:43 PM | #28 | |
4004
Rep 1,003
With wire nuts, make sure you have the right size for the wires (gauge and number). Solid wires should not be pre-twisted together. Just cut to the appropriate length, line them up, and twist the connector on tight. That is a tight mechanical and solid electrical connection, insulated. If stranded wires are involved, twist each wire individually, trim to length if needed, and then proceed as with solid wires. If you do that, they are fast and versatile and pretty easy to store in a junction box, fixture or whatever. |
03-23-2022, 04:55 PM | #29 | |
344
Rep 39
Drives: 2023 X3 M40i
vreihen1622169.50 |
03-23-2022, 05:34 PM | #30 |
22170
Rep 1,031
Double check the published UL specs, as I am only repeating what I have been told. I am not a member of the wire nut cartel to know what the exact UL specs for every use are:
https://www.wago.com/us/wire-splicin...21-413#details Approvals per UL 486C Rated voltage UL (Use Group C) 600V Rated current UL (Use Group C) 20A
Currently BMW-less.
03-23-2022, 05:50 PM | #31 | |
Space Force - 4 Star General
11506
Rep 3,265
03-23-2022, 06:10 PM | #32 |
22170
Rep 1,031
I have not had problems undoing a WAGO connector. I just pop the lever using a small screwdriver, and the wire pops right out.....
Currently BMW-less.
03-24-2022, 10:29 PM | #33 |
Free Thinker
19787
Rep 7,561
More questions. I've been looking at Philips Hue Wall Switch Modules. Basically you wire all the copper together (except the ground) so the light is always powered, then you wire the Switch Module into the existing toggle and tuck everything back into the box. The switch now turns on the light (which must be a Philips Hue bulb) through the Hue Hub system. Sounds easy enough and looks easy enough for a single pole light. But all they say about 3-way setups is that you need the same module at each switch. That makes sense. But how do you combine the wires in a 3-way switch so the light is alway powered on? You have a Line, a Load, a Traveler, and a Neutral (and of course, the ground). Assuming the Neutral is only connected to another Neutral in the back of the box, do you just wire the Line, Load, and Traveler together?
https://www.philips-hue.com/en-us/p/...e/046677571160
03-27-2022, 03:14 PM | #34 | |
Free Thinker
19787
Rep 7,561
vreihen1622169.50 |
03-27-2022, 07:33 PM | #35 |
976
Rep 5,555
03-27-2022, 08:05 PM | #36 | |
4004
Rep 1,003
Then, if I was going to do this, I would just rig a test setup with a light and two switches (3-way) on a bench. Then put the Hue in where you think the instructions call for it and see how it behaves. Will cost you some wire, a socket and bulb, two switches and two? Hues. Maybe some of it will survive the test to be reused. |
03-27-2022, 08:56 PM | #39 |
Free Thinker
19787
Rep 7,561
I do have a pro coming out this week. Finally. Tough getting trades folks to come out to your house these days. But I intend to have this person explain some of this crazy wiring to me and maybe install some switches for me. I'm always happy to pay for a pro to do work. I'm just not willing to wait 6 months for it.
vreihen1622169.50 DETRoadster11506.00 |
03-28-2022, 07:40 AM | #42 | |
22170
Rep 1,031
Currently BMW-less.
M_Six19787.00 DETRoadster11506.00 |
03-28-2022, 09:32 AM | #43 |
11506
Rep 3,265
Nice! I used something similar when they first came out and I'm pretty sure there was no simple release mechanism. Kind of like a zip-tie in that, yeah, sure, you could release it and use over if you were Hell bent to do so but for the hassle you'd just snip it off and start over. These guys look to have improved the design considerably..
vreihen1622169.50 |
03-28-2022, 12:37 PM | #44 | |
22170
Rep 1,031
WAGO is designed/made in Germany, so it has to be good.....
Currently BMW-less.
DETRoadster11506.00 antgenn344.00 |
