      07-16-2021, 03:37 PM   #23
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3129
2,784
Drives: CT5V-Blackwing
I don't know which wheel number I have, they are the honeycomb copies of the old TransAm wheels from the 70s.
They look fabulous, but they are a PITA to clean.
I just bought a new sponge, it's a big one used for cleaning grout off of tile work and nice and soft. I'm hoping that it will be easier to get into all of those holes. I'll cut it in half first.
I don't believe in this "spray on spray off" nonsense, as you have to get in there with a brush or a sponge or something and physically wipe off the dust. I also never, never use a pressure washer on anything related to the car, unless I'm trying to strip off paint. That's just too abrasive.
FWIW, I use Griot's wheel cleaner, it works well, smells good (unlike Iron-X) and I believe is the same as P21S but a bit less expensive.
Current inventory:
F22 M240ix (wifey)
G29 Supra with three pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
GixY2K553.50
      07-18-2021, 11:12 PM   #24
Ximian
Ximian's Avatar
2125
2,031
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
Originally Posted by themnmd View Post
CarPro iron x for the dust. Ceramic coating for wheels. Doesn't really stop the dust but way easier to clean. I use CarPro hydro lite 2. It's a spray on wash off , I get 6 - 8 weeks per application. Tip make sure wheels are perfectly clean or ceramic coating will seal in the dirt. Of course you can use a coating that lasts longer, I use the hydro lite because it's convenient. Oh I use both with a power washer, not a must though.
Don't use IronX for wheels, that's overkill. I use it to decontaminate the paint after winter to get rid of the small yellow spots on white paint.
Sonax wheel cleaner would work better as a spray on. I only use a towel to wipe of the brake dust and it works well.
themnmd1714.00
      07-19-2021, 08:04 AM   #25
LivinLrge
LivinLrge's Avatar
219
355
Drives: M4 Competition
2021 BMW M4 Comp  [0.00]
2011 335is  [9.83]
Another vote for Sonax...works great.
2011 335IS - Alpine White/Coral Red
2021 M4 Comp - Alpine White/Fiona Red
      07-20-2021, 10:28 PM   #26
snareman
Leave the gun. Take the Canoli.
snareman's Avatar
10518
8,520
Drives: ///M8 & X5 ///M60
Looks like you have the 826 Bicolor. See below, but although I did end up using a brush the spray on spray off would have worked pretty well.
Current: 2025 X5 M60
Retired: 2023 M8 |||
2023 X3 M40 ||| 2021 M4 ||| 2018 M4 ||| 2017 M4 ||| 2014 435 ||| 2009 335 ||| 2007 335
      07-20-2021, 10:34 PM   #27
snareman
snareman's Avatar
10518
8,520
So at all of your recommendations I picked up some Sonax Wheel Cleaner Plus and Sonax Wheel Rim Shield. The directions say you have to put the wheel cleaner on a cool dry wheel and let it sit for 5min so I knew I couldn't go to the carwash as the wheels would have been hot from the drive there.
So, I pulled my car out into the driveway, sprayed on the wheel cleaner and let it sit. It did start to change color as they say. I think it would have done pretty well just like that, but I did get a long thin wheel brush that I allowed me to get back in the inner parts of the wheel (the large flat round area in the middle. I then filled up a garden sprayer with soft water from my sink and rinsed them off. Higher pressure would have been nice, but that would have been hard water from the hose (and my hose is also a hassle to get out as it lives in my garage when it's not connected). Dried the wheels and applied the Rim Shield and let the car sit for an hour as directed. The whole process took a little over 30min.
The wheels are as close to looking factory clean fresh as they've ever been. Time will tell how effective the Rim Shield will be at either not having the brake dust stick as much and how easy it will wash off in the touchless wash. For the moment though, the wheels look AMAZING.
LuvMyE923128.50
npcars70.00
      07-21-2021, 12:14 AM   #28
sansri
19
37
Drives: 2018 G01 X3 M40i
👍 Sonax works great. I would recommend trying it with a garden hose - usually I end up just spraying Sonax and then washing the the wheels with the hose. Finally do a light second round on the sections missed. This gets most of the wheel without too work ( 5-10 minutes or less ). Just get the large refill
vitipr179.50
      07-21-2021, 07:30 AM   #29
merlin3008
merlin3008's Avatar
941
905
Drives: 2025 M3 Comp xDrive
I definitely second Sonax. Great product. I usually let it sit and then use the softest brushes I can find to agitate the inner sections of the rim. I haven’t coated my rims yet, but I just might when my M3 arrives. I’ve always found that a wipe down with some sort of non-greasy QD once dry, helps to improve appearance.
      07-21-2021, 07:31 AM   #30
LuvMyE92
LuvMyE92's Avatar
3129
2,784
Correct. Thanks for the write-up, looks like i need to try the Sonax.
Current inventory:
F22 M240ix (wifey)
snareman10517.50
Limegrntaln14419.00
      07-29-2021, 04:40 AM   #31
LivinLrge
LivinLrge's Avatar
219
355
2011 335is  [9.83]
I use this plus Sonax.
Car Wheel Brush, Premium Automotive Detailer and Tire Brush Cleaning Kit for Bikes, Engines, Trucks, Boats, Equipment, Exhaust Tips, Premium Water-Powered Multi-Purpose Rim Brush from Brush Hero https://www.amazon.com/dp/B00Z7N7KGW...UTF8&psc=1
      07-29-2021, 06:29 AM   #32
modat
2491
1,739
Drives: 2022 IOMG M3 Xdrive
Be careful with home water softeners if you have one. They tend to have salt filters
      08-03-2021, 04:47 PM   #33
corbs09
361
480
Drives: 09 335i
Another +1 for Sonax Wheel Cleaner Plus. I actually just picked up a gallon to refill my spray bottle. Hands down best wheel cleaner I have used. Make sure you use it on COOL to the touch wheels and you aren't washing the car in the sun... it will bake on quick and you dont want that. Also there are a few versions of the Sonax wheel cleaner... the Plus is the version you want.
      08-17-2021, 08:22 PM   #34
Vigilant
Vigilant's Avatar
308
869
Drives: Cautiously fast
Try Poorboys wheel cleaner. Make sure you buy enough dispensers as the fluid will clog the lines. Spray on and wash. No manual work. Have used on my F80 for 6 years.
https://www.autogeek.net/pbsrwc128.html
2022 BSM G80 Comp X-drive
      08-18-2021, 02:32 PM   #35
corbs09
361
480
Drives: 09 335i
Spray on:
Spray Off:
Works like a charm. Then pull the car forward a few feet and tap the brakes to get the surface rust off rotors, blow wheels with compressed air to remove the "rust dust" and you're done in less than 15 mins.
Appreciate 4
snareman10517.50
Limegrntaln14419.00
      08-19-2021, 02:27 PM   #36
Ginster6
341
238
Drives: G87 with a Stick
Originally Posted by corbs09 View Post
Spray on:
Spray Off:
I wish it was that easy.. Sonax Plus does not work for me... have to spray 2-3 & brush it to make it work.
so it is basically a bottle per wash. sad......
      08-19-2021, 02:38 PM   #37
snareman
snareman's Avatar
10518
8,520
Yea, mine definitely required some agitation from a brush. Maybe if I had a power washer and power blower.
      08-20-2021, 03:15 PM   #38
corbs09
361
480
Drives: 09 335i
I use a power washer on a lower setting, maybe that has something to do with it. The other thing I do is ensure the wheels are cool to the touch and I let it sit on for about 3 minutes.
      08-20-2021, 10:04 PM   #39
Limegrntaln
Limegrntaln's Avatar
14419
7,255
Drives: 2024 Model S Plaid
Pressure washer all day long. You just need to make sure you have the right nozzle size to go with the pressure washer. You dont need more than 1,000 PSI. Doesnt matter what pressure washer you have, the nozzles adjust the pressure of the jet.
Sonax wheel cleaner is good. I like P&S Brake Buster.
YT: G Dubyou
      08-20-2021, 11:30 PM   #40
Bimmer TiM3
257
141
Drives: BMW G80 M3 Competition
Pressure washer first then a quality wheel cleaner. Agitate with brush. Power wash off. Foam cannon entire car. Let sit 5 mins. Spray off. Soap with a wheel brush. Spray off. Wash rest of car. Dry. Vacuum. Windows. Interior. Quick drive around the neighborhood to get surface rust off. Clean that off with a microfiber towel. Take a shower. Go out to eat and start crying when you get to restaurant and wheels look like shit
Appreciate 13
jeffrc3m3203.00
M3-san258.50
Limegrntaln14419.00
rdasari87.50
m4ml2067.50
playswcars5101.50
dini_g80218.50
      08-29-2021, 05:48 PM   #41
Limegrntaln
14419
7,255
Exact reason I ordered the CCBs, you cant drive 10 miles without the wheels looking like you havent even washed them.
YT: G Dubyou
      08-29-2021, 05:49 PM   #42
snareman
snareman's Avatar
10518
8,520
Unfortunately clean wheels aren't worth $8000 to me. And, I like the red calipers.
Limegrntaln14419.00
      08-29-2021, 06:49 PM   #43
Limegrntaln
14419
7,255
Yeah, unfortunately, the OCD in me, hates brake dust. And I just like the bigger rotors, and I've never had a chance with other cars to even get them, so, for me, if I was going to build a car, I would spec everything I wanted. Kicking myself for not getting the Carbon Exterior package, but $103K was already giving me chest pains... But, now that the car is at the port, I think I want to call and add it, port installed.
YT: G Dubyou
      08-29-2021, 06:54 PM   #44
snareman
snareman's Avatar
10518
8,520
I just swapped out the interior trim for CF after I got the car. Everything is SO MUCH more expensive after the fact. Spent probably close to $2k on a $900 option. If it's the same price as when you originally ordered the car doing it port installed and you have a thought that you'll regret it later definitely do it now.
Limegrntaln14419.00
