      09-25-2008, 10:46 AM   #23
cas
22
211
Drives: CV
its happening b/c you didnt prime the walls first. you can actually tint the primer and it will help with the final coat
      09-25-2008, 10:51 AM   #24
darkcloud
darkcloud's Avatar
361
2,385
Drives: 09 VW JSW
2006 325i  [0.00]
You def. should have primed the walls first. Just because the wall was already painted doesn't mean it doesn't still need primed.
I just painted every room in my house. If I didn't prime nearly everything each room would have easily need 3 coats of paint, instead I primed and only needed 2 coats of paint. Yes I still did 3 coats but prime is wayyy cheaper then paint and you don't have to be any where near as neat with the prime as you do with the paint.
This also could be the Ralph Lauren paint but I've never used it before. I used all aqua velva benjamin moore paint which is supposedly one of the best paints available.
retired 06 E90 325i
New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter
      09-25-2008, 11:06 AM   #25
UncleWede
UncleWede's Avatar
18596
9,435
Looks more like a "shiner" where you put a less-glossy over a glossy, and the underlyiing gloss is shining thru. Also could be latex over oil.
      09-25-2008, 11:36 AM   #26
ideliver
ideliver's Avatar
248
1,247
Drives: E60 M5, E71 X6M, E46 M3
2006 BMW E46 M3 'vert  [0.00]
2008 BMW M5  [0.00]
2011 BMW E92  [0.00]
2012 BMW X6M  [0.00]
2003 E46 M3  [0.00]
no need for primer...go to SW for help...looks like you dry rolled...you may wnat to start with a more forgiving paint (such as egg-shell) and stay away from satins and semi-gloss...until you get your technique down...
painting is actually more than just slopping some paint on the wall...good luck
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
      09-25-2008, 01:00 PM   #27
badfish
badfish's Avatar
102
1,016
Drives: E92 AW M3
2008 M3  [0.00]
Ditto. It might cost you a little more to start off with a tinted primer but it will save you loads of work and you will end up with a better result. Trust me, I know from experience. To go from a white wall to a color like red will take a bunch of coats without a primer to get it even. With a tinted primer, it's a piece of cake. You can fix what you have by using more coats though.
      09-25-2008, 01:13 PM   #28
KL2DC
Moderator
KL2DC's Avatar
327
17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
2015 F36 428i  [0.00]
2011 E90 328i  [0.00]
2006 E85 Z4 3.0i  [0.00]
e92k335i: wow that paint looks nice, smooth and even...good job
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call!
      09-26-2008, 02:35 AM   #29
synclastica_86
synclastica_86's Avatar
Hong Kong
250
735
Drives: F32 435i, E92 M3, S550
2 ///M cars and can't afford a painter?
Current: BMW F32 435iA M-Sports; BMW E92 M3, M-DCT; Mercedes W221 S550 4matic; Ford Fiesta ST; Nissan Silvia S15 Spec-R
Retired: BMW E93 323iA; BMW E85 Z4 3.0i, SMG; Lexus IS 250 AWD; Lexus GX 470; Mercedes W203 C230 Sportscoupe; Peugeot 206 S16; Peugeot 206 RC
      09-26-2008, 02:48 AM   #30
koreez88
Всем привет ;)
151
3,358
Drives: Tesla
Originally Posted by e92K335i View Post
First off give it 24 hours to dry, once you see the effected area (you should see where some area have less paint than others.) you can touch it up. How many coats did you apply already? One of my room took 2-3 coats to get rid of those blotchy area's. Hope that helps!
DESPERATELY needs mouldings.
