      05-27-2018, 10:35 PM   #23
SuckaGDog
130
617
Drives: M5, C63 AMG Black Series
Originally Posted by BM dnobagaV View Post
Rather simple. Give the type of wheels/tires you got on & the tire pressure you run at.
I'm asking because my AMG finally arrived from the shop. Driving the last few days, I could literally feel every bump even in comfort mode. Stock PSI suggested is 51. Seriously, 51.
That's fully loaded, up to 186mph, with 4 passengers. Why would I ever be in that scenario? I assume it would be better for daily driving in CA(land of bad roads) if I let them to ~40psi?
Stock at 33 in my 528i and the car is an absolute dream. Like on a cloud.
Are you looking at the door pressures from the door jam? If so, those are incorrect as they’re for full capacity. You need to reference to the tire pressure sticker inside the fuel filler cap. I was confused when my Black Series was delivered.
      05-27-2018, 10:51 PM   #24
BM dnobagaV
BM dnobagaV's Avatar
454
459
Drives: 2010 BMW 528i
What do you run on your C63?
      05-28-2018, 09:08 AM   #25
SuckaGDog
130
617
33psi all around (cold tires). I measure them in the morning in the garage after the car has been sitting overnight.
      05-28-2018, 04:13 PM   #26
hellokitty
hellokitty's Avatar
2955
3,734
Drives: '17 M3 ZCP DCT
32 psi on stock 666m wheels and PSS tires.
also use a QUALITY air pressure gauge to get it down to the exact psi on all 4 corners. my acceleration in a straight line improved tremendously after i purchased a solid analog gauge over my digital one. even the slightest differential in PSI can make the car feel sketchy on WOT.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      05-28-2018, 10:14 PM   #27
lemetier
Plenipotentiary
lemetier's Avatar
2616
3,046
Drives: Yes
NHTSA has required a specific door jamb label that can only display the minimum cold pressure under maximum certified operating load as originally installed by the manufacturer for several years now. Specific to your CLS63, that's 51psi all around due to the Performance Pack speed limiter increase (high speed aerodynamic load tire sidewall compression compensation).
For the original OE tires (temperature, size, load index, and speed rating), the recommended pressures are:
- Operation up to 155mph
Light Load: 38f/35r
Normal Load: 39f/39r
- Operation between 156mph - 186mph
Light Load: 48f/44r
Normal Load: 51f/51r
Recommended pressures are specific to the application and tire design specifications. For example, I have two vehicles that are the same make/model, fitted with identical tires, but they have different equipment. At normal loads, the lighter one is recommended 43f/51r, while the heavier one is 48f/61r regardless of load.
Originally Posted by cxp213 View Post
When people refer to "cold" tire pressures, they're not talking about a specific temperature threshold
Actually there is a specific cold temperature (20°C/68°f). The ambient acclimation correction factor is 1.45psi/0.1bar per 10°C/18°F
      05-28-2018, 11:08 PM   #28
Mbbrewer
Mbbrewer's Avatar
151
672
Drives: 550i
Total placebo
      05-28-2018, 11:14 PM   #29
xQx
Australia
907
1,004
Drives: 2008 BMW 135i (E88 N54 6AT)
SIXTY ONE PSI??!!!
Damn, I'd be afraid to fill that thing up. I hope it's well mounted on its rim.
      05-29-2018, 12:32 AM   #30
cxp213
cxp213's Avatar
313
525
Drives: M235i
That's great but look at the type of questions and responses here. Do you really think getting more technical is beneficial to them? Lol, when was the last time you spoke to anybody about cold tire pressures, measured ambient then adjusted your tires based on that?
