      02-14-2008, 12:26 PM   #23
sparkyg
sparkyg's Avatar
154
3,521
Drives: A6 Allroad
Originally Posted by down4it View Post
Not exactly, Inconel has a much higher corrosion/heat resistance over titanium but it so heavy (much heavier than steel) i dont understand how someone could use it for an exhaust on a performance car, it is used inside the hotside of a turbo for the turbine fan blade that gets hotter than any exhaust... Titanium is already overkill for an exhaust, borla uses T304 stainless steel and has a million mile warranty, what more could you need...
The inconel is a high Nickel alloy. The weight of it is the same as SST, not a significant factor comapring to other SST exhausts.
The reason for inconel is high temp rating, no corrosion at the welds (welded 304SST can and will rust unless you heat treat it, and even then 304SST is the shitiest SST out there), and as it heats and cools it creates cool blue green colors to the metal so there is a gee whiz factor to it.
The inconel is the most superior metal you can use, hands down. Nothing will be close in tems of strength/corrosion/weldabilty.
Is it expensive, yes, probably the most expensive metal out there next to Ti.
Ti alloy would be light but useless in terms of strength. It would need signicant cold work to equal the strength of the Inconel.
Again the weight savings might be significant but alot of money to just save weight.
      02-14-2008, 01:59 PM   #24
BayAreaE92
BayAreaE92's Avatar
20
368
Drives: 91' 850i
1991 850i  [7.75]
2007 328i Coupe  [0.00]
FOR 20k that exhaust note better give me an orgasm everytime I so much as tap the gas pedal!
      02-14-2008, 03:20 PM   #25
nusevad
O! So Sour!!
nusevad's Avatar
556
15,612
Drives: Fast 240z / Slow M3
1971 Datsun 240z  [0.00]
2008 M3  [9.60]
Originally Posted by Spool View Post
Meh, BJs are over rated...
Nowadays you put your legs over your head and take an RJ
Rim Job
How about a ZJ?
and if you have to ask what it is, you probably cant afford it.
