      01-18-2014, 03:32 PM   #353
Soorena
94
850
Drives: M3 6MT
Originally Posted by tuj View Post
http://www.epi-eng.com/piston_engine..._cup_to_f1.htm
The BMEP of a 'antiquated' pushrod, single-cam, 2-valve V8 engine is surprisingly good when properly developed. Chevy has put a lot of effort into flowing those LSx heads and figuring how how to get the most out of their 1960's technology. Heck they even have VVT finally.
Key phrase.
Originally Posted by son_of_siggy View Post
Most run both a MAF and MAP. The rich condition would only appear briefly when you build boost and then suddenly close the throttle. We're talking very quick spikes. In bypass mode you're not building boost and bypassing the air, you're simply not building boost at all. Supercharger becomes a like a low resistance pulley.
Oh Ok thanks. So it's more like the clutch system in AMG M113 engines.
Originally Posted by quagmire View Post
OHV and OHC are both around the same age. So you're not going to win any latest tech argument. The first DOHC engine was made in 1912. First OHV was 1904 if my quick research is correct. Yes DOHC is technically newer, but in terms of DOHC being more modern, that 7 year difference when both motor designs are 100 years old is hardly significant. Both are old designs.
I never mentioned anything about tech involved in OHC and OHV. I think you misread. I said Eaton TVS are more advanced than old Mooneyhams.
I think he was talking about physical size. A 6.2 liter DOHC V8 will be quite a bit bigger physically than the LT1/LT4 at the same displacement.
I thought wrong then. I was thinking about displacement. I apologize MediaArtist for the misunderstanding.
      01-18-2014, 04:40 PM   #354
son_of_siggy
17
432
Drives: CTS-V
Originally Posted by Soorena View Post
Oh Ok thanks. So it's more like the clutch system in AMG M113 engine.
I don't know how the z06 is setup. On my mustang the air simply bypassed the supercharger screws, so there was nothing to compress. The screws still spun, but without compression they spun easily.
      01-18-2014, 05:52 PM   #355
Kayani_1
Kayani_1's Avatar
85
1,656
Drives: BMW E92/E60
What an awesome beast
The coolest part is that you can run this car in 4 cylinder configuration, NA V8 cylinder configuration, and Forced inducted V8 configuration. Everything on the car is track and racing inspired.
nickname"BAD 3",MHD E85 tune,RennArt catback non-resonated exhaust,VRSF Downpipes, VRSF 7"FMIC,VRSF stock side inlets,SSQV BOV,ECS CP,M-performance alcantara steering,retrofit M3 paddle shifters,Alpina B3 tranny flash,AFE power seal CAI,LED angels,ST Coilovers,M3 upper/lower control arms,E93 M3 Front Swaybar ,235/35/19x9 ,275/30/19x9.5. M sport bumpers, CF diffuser. When in doubt..flat out.
      01-19-2014, 07:11 AM   #356
conradb
74
493
Drives: 2011 E92 M3 (ZCP/DCT/ZCV)
Originally Posted by wisesoul View Post
I can almost promise you guys there won't be a ZR-1, it just doesn't make sense. I have a hard time imagining 700-800 HP being safe and usable for a RWD street car. C4 and C6 had a ZR-1, C5 didn't, and C7 won't. Mark my words. But perhaps a higher performance Z07 package Z06 will be in the works.
lol you don't know American muscle culture very well, do you?
      01-21-2014, 01:21 PM   #357
pgviper
289
833
Drives: X3m40
Originally Posted by Year's_End View Post
I'm absolutely not trying to add fuel to the fire, and I love the small block mills that Chevy pumps out, but I want to chime in here since this always gets brought up.
People quote the fuel efficiency of these V8s in relation to their size and whatnot, but let's use the C6, C6 Z06, and E92 M3's figures you posted. Curb weight of these respective models has a lot to do with overall efficiency; the LS3 is pushing 3,179 pounds, while the LS7 is pushing 3,132. Meanwhile, the S65 has to deal with a hair over 3,700 pounds. That's a 570 pound weight difference between the two. That will severely impact fuel economy figures no matter how the engine is made.
Just food for thought.
No problem, I don't mind discussion. MPG only decreases to 24 mpg on the highway for a 2010 camaro (ls3) which comes in at over 3800 lbs. Still doing much better than the M3.
MPG really comes down to how much torque an engine can generate while doing the least amount of work (using the least amount of energy). The S65 lacks in that department. This is simply the nature of these engines.
So even though the S65 is more "advanced" when it comes to downright performance, it lacks in all categories except for how high it can rev which to some allows it to win in the fun category.
      01-22-2014, 05:53 PM   #358
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
907
3,698
Drives: '17 C2, GTI, Z4 3.0si Racecar
How they do that? If i'm not mistaken the MAF sensor is pre-supercharger and if you dump boost it would just run rich? How ECU measure the actual intake air flow then? Does it have a post-supercharger MAP sensor?
http://www.corvetteactioncenter.com/..._pursuit3.html
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      01-24-2014, 05:35 AM   #359
wisesoul
Savoir Faire
wisesoul's Avatar
Philippines
83
1,771
Drives: 2013 BMW M5
http://www.autoblog.com/2014/01/14/c...not-happening/
Yeah...Definitely not happening
Current: Alpine White F10 M5|H&R springs|12mm/10mm spacers|Eisenmann Race
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel
Sold:E46 323i
      01-24-2014, 11:44 AM   #360
MediaArtist
There is No Substitute
MediaArtist's Avatar
77
1,186
Drives: Audi A6, 997 GT3 RS, E90 335i
That makes sense. It would be extremely expensive to create a car that is appreciably better than what GM has done with the Z06.
'13 Audi A6
'07 Porsche GT3 RS
'08 BMW E90 335i
      01-24-2014, 02:46 PM   #361
CirrusSR22
352
1,326
Drives: BMW
In one of those videos with the engineers/chief designers/etc they mention there's more power to get out of this engine. Seemed like a hint it'll get a power bump or special edition in the future.
      01-24-2014, 09:31 PM   #362
TunedM2C
TunedM2C's Avatar
852
4,190
Drives: 2016 LBB M2
Some interesting tidbits from a recent closed door session about the Z06.
http://forums.corvetteforum.com/c7-z...m-members.html
      01-24-2014, 10:42 PM   #363
hellrotm
4146
6,924
Drives: F80
Originally Posted by Strongbark View Post
Can't wait to see this thing on the track.
Tomorrow. 24hr of Daytona.
      02-11-2014, 04:45 PM   #364
TunedM2C
TunedM2C's Avatar
852
4,190
Drives: 2016 LBB M2
Go big or go home!
      02-11-2014, 04:51 PM   #365
TunedM2C
TunedM2C's Avatar
852
4,190
Drives: 2016 LBB M2
I'm really digging the technology that will be coming with this car.
      08-22-2014, 10:49 AM   #366
Jamesons Viggen
197
3,780
Drives: '98 M Roadster stg 2+ S/C
Originally Posted by Viktimize View Post
I will gladly eat crow if I'm wrong. But I don't get how everyone thinks it is so far fetched? Even last years Z06 was topping out over 100k. The cost of parts and manufacturing has not decreased, so how is this new ZR1 going to cost less than last years ZR1? It's impossible.
Oh and I didn't say it is going to start around 120k. I said the car will cost roughly 120k. I'm referring to a car someone would actually buy, not a base model MSRP that is on the books but doesn't really exist.
Start eating crow
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      08-22-2014, 10:52 AM   #367
Year's_End
Year's_End's Avatar
1248
12,446
Drives: 2020 Shelby GT350
IS THIS REAL LIFE
Want to get your hands on the most powerful vehicle GM has ever made? It may be time to call your bank manager, financial adviser and whoever else helps you get your monetary ducks in a row, because Chevy has now revealed pricing information for the new 2015 Corvette Z06.
Pricing starts at $78,995 for the coupe and $83,995 for the convertible. Both those figures include destination, but don't include things like tax, title, license and optional equipment. And as we revealed when the order guide surfaced, there is some enticing optional equipment on offer.
An extra $2,995 will get you the Carbon Fiber Ground Effects package with enhanced aero. $7,995 will get you the Z07 Performance Package with Brembo carbon-ceramic brakes, upgraded tires and even more aggressive aero. There are three trim levels available and a host of other packages and options you can read all about in the press release below, from the Premium Package leather trim to the Performance Data Recorder.
No matter which way you set it up, though, you're getting a 6.2-liter supercharged V8 with 650 horsepower and just as much torque. And though the price of entry may seem high, it comes down to a downright steal compared to the six figures Chevy got for the previous ZR1 (whose place the new Z06 effectively takes) and which Dodge gets for a new Viper.
http://www.autoblog.com/2014/08/22/c...cing-official/
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      08-22-2014, 11:12 AM   #368
335m
134
1,166
Drives: 08 e92 M3
Wait, this thing comes with a dashcam installed? Is this Russia?
2008 e92 M3: Gintani Sport w/ Topspeed Catless X-Pipe, KW-V3
      08-22-2014, 12:06 PM   #369
TunedM2C
TunedM2C's Avatar
852
4,190
Drives: 2016 LBB M2
^It gets better.
http://speedsociety.com/2015-corvett...vette/?var=htc
      08-22-2014, 12:17 PM   #370
Vigilante375
115
1,158
Drives: 2012 AW 6M 135i
My thing with the valet mode.....is why they didn't make it so you're limited going 25 mph (maybe slower), RPMs no higher than lets say.....2k and limit the throttle to less than 50%?
Cool features but they missed one big one for a true "valet" mode.
Oh yea, under $100k fully loaded Z06! The base price is what is amazing. I cant wait to see this car tear it up on the road courses/track.
      08-22-2014, 12:27 PM   #371
MisterSkiMask
151
2,014
Drives: I Can not say
A loaded 435 vert gets you up to base Z06 price...I know, different cars but the '3 series' pricing is getting out of hand.
      08-22-2014, 01:50 PM   #372
335m
134
1,166
Drives: 08 e92 M3
Considering the Hellcat and whatever Mustang ends up being on par with it, Chevy will have to release something in the 700hp range in order to compete with that market. Even if it is a tuned/lightweight version of the Z06.
      08-22-2014, 02:43 PM   #373
pgviper
289
833
Drives: X3m40
I wouldn't be surprised if we see a no compromise version of the z06 similar to the z/28.
Serious weight reduction and naturally aspirated. Imagine the process that brough the ls3 to the lt1 is given to the ls7. 550-600 hp naturally aspirated with 300 lb weight reduction would be sublime.
      08-22-2014, 02:55 PM   #374
DieGrüneHölle
1309
2,785
Drives: M
Chevy can do something with the next gen Camaro, or whatever. The Z06 is a different animal for a different buyer. It is a complete package, not some motor bolted to a terrible chassis like the Hellcat. Don't get me wrong the Hellcat is cool, glad to see it coming out of Detroit. But the Z06 is now a track monster, on par with some of the exotics costing 2-3x the money.
Tags
2015, corvette, stingray, z06, z07
