03-19-2019, 10:03 PM | #3213 |
1082
Rep 713
Welp, sent in my CCW permit.
IllSic_Design2126.50 PINeely1079.50 |
03-20-2019, 02:42 AM | #3214 |
205
Rep 157
In California? No, your life is forfeit and you just have to run and hope for the best until you run out of places to run, and then you can protect yourself, but if you do and your pistol holds more rounds than the califonian overlords think is the right number, then you might be screwed.
sspade2507.50 |
03-20-2019, 02:50 AM | #3215 | |
63
Rep 87
Drives: 2018 M2 LCI
Not true. Do the math, force equals mass x acceleration. .40 has much less " force" than a .357 magnum. .357; Standard 158 gr at 1250 FPS 197,000 cup vs .40 s&w ; 180 gr at 960 ; 171000 cup. Agreeing and disagreeing has nothing to do with power factor . Stay in your lane . Please. Polynesians ? LMAO . You mean the Filipino insurrectos aka moros. The myth of the .45 is a tough one . Too much Hollywood . Standard issue us military 230 gr ball at 800 FPS. That is 184,000 cup. Yawn . The 40 is on it's way out again . Because marksmanship is everything . The Marine Spec Ops nominally are issued a .45 ACP colt 1911 variant called the M45. No one wanted to carry it . Several years later the MARSOC got a waiver to purchase Glock 17s in 9mm due to reliability and because they train like madmen, AND IF YOU CAN SHOOT, A 9MM DOES THE JOB. The .40 came into being because the smaller FBI agents couldn't handle the full 10mm. They dumbed it down and the 40 came into being. NAVY Special Warfare and ARMY SF also use 9mm . The bullets you might be referring to are called Hollow Points , not hollow tips. A double tap, aka a controlled pair, is no guarantee either . If that is your mindset , you should leave it at home . You shoot until the threat no longer exists . Stand there flat footed and gloating with your perfect pair on target and you're a DEAD MAN . You have the rest of your life to keep shooting until you've won a gunfight . Two rounds means nothing if you didn't stop that fight. No handgun cartridge is an "instant man stopper ". It is a myth . Not enough trauma . |
Grumpy Old Man6470.00 |
03-20-2019, 03:01 AM | #3216 | |
288
Rep 428
Since someone mentioned CA, there is a code where you can use deadly force if you fear that your life or other lives are in danger.. But I'm not sure how effective is a spoon is in saving your life there. 🤣 Seriously your friend needs to look up the law where ever they are located. |
03-20-2019, 03:05 AM | #3217 | |
288
Rep 428
9mm is easier for me to get back on target based on the guns I've shot. |
03-20-2019, 03:25 AM | #3218 | |
63
Rep 87
Drives: 2018 M2 LCI
03-20-2019, 07:37 AM | #3219 | |
6470
Rep 1,966
03-20-2019, 09:54 AM | #3220 |
2508
Rep 5,469
Drives: F30
For the record... out here they are teaching us to empty our clip if someone points a weapon at you (in a threatening manner). That's the training I've received so that's the action I will take.
03-20-2019, 10:12 AM | #3222 | |
2508
Rep 5,469
Drives: F30
As I said... someone will make a mistake... |
03-20-2019, 10:21 AM | #3223 |
1207
Rep 1,002
03-20-2019, 10:24 AM | #3224 |
6470
Rep 1,966
There's nothing wrong with a revolver. It may be a bit more difficult to conceal but they are accurate, never have mechanical stoppages and very easy to shoot without having to worry about external safeties etc. The main drawback is capacity.
03-20-2019, 10:29 AM | #3225 | |
1207
Rep 1,002
A 15 round mag dump with a small chance of a stoppage seems like better odds than 6 rounds followed by a long reload time. |
03-20-2019, 10:36 AM | #3226 | |
6470
Rep 1,966
i think the biggest issue with CCW is practice and confidence. You want good muscle memory when things start happening. i suspect most people have some idea of what they would do, in reality you don't get to pick what happens in advance but must react. Get out to the fight, move to cover or escape is better. The ability to get the gun out of the holster requires practice.....i've seen seasoned shooters drop the pistol on the draw. And then there is accuracy, shooting a paper target is easy, it's not presenting a threat. I like to do shooting and moving drills as opposed to standing in a stall and putting holes in a singe paper target. Multiple targets and various size and distances......practice practice practice. If you miss, you are responsible for every round you fire. |
03-20-2019, 10:53 AM | #3227 |
11822
Rep 23,186
Not standard for sure would.carry revolver as my bug, as leg gun maybe. Also wouldn't ever position my gun in that manner. Even at rest I make sure its not pointed at things I dont intend to shoot.
zentanker205.00 |
03-20-2019, 11:58 AM | #3228 |
Guest
Rep n/a
Drives:
03-20-2019, 01:23 PM | #3229 | |
7935
Rep 1,923
So the number of rounds seems to pale in comparison to how accurately (without stoppages) you can get your rounds to target. Thus, use what you shoot best. Whether that's a revolver or not. |
Grumpy Old Man6470.00 Lucky John617.00 |
03-20-2019, 03:13 PM | #3230 |
1082
Rep 713
That would be some Russia stuff. Some of the most crazy stuff.
The first one was the dumbest one, like bulletproof vests fail to stop things all the time. You really want your life ended in a gun drill? The second drill does not make much sense other than just testing focus, but I am not sure what situation people who arent bad guys would be pulling/pushing/shooting guns near your head/trying to blow your vision while you shoot at bad guys. Surely there has to be a better way to test your focus in situations. |
03-20-2019, 05:36 PM | #3231 | |
1887
Rep 2,174
You shoot ONLY until the immediate threat is neutralized. While you are throwing extra lead you hurt your self 3 ways.: You deplete your ammo. You never know if there is an unseen threat. While you are shooting you can not scan the area. As soon as the threat is eliminated you want to take a step or two to force another shooter to reacquire his target (you). And you immediately use just your eyes to look around As Grumpy said..every round you put out there is owned by you. Nothing wrong with a Revolver. I do not use one though. I only carry 5+1 in my .380 and am very comfortable with it. Not even mildly concerned its not enough. |
03-20-2019, 05:42 PM | #3232 |
205
Rep 157
