08-24-2023, 02:05 PM | #265 |
5778
Rep 11,305
While there is not a vapor collection system, the valve covers do have baffles leading to the hoses that go to the turbo inlet pipes. The baffles supposedly do a pretty good job trapping oil. My 08 535xi had DI but a different vent system with PCV valves and the amount of goo in the intake ports at 90k miles was surprising — they were about 1/4 blocked. It looks like it would be an engine out job to clean the intake ports on an F90.
I have been running water/meth injection for a couple of years on my F90. It goes through the intake manifolds and supposedly helps reduce carbon build up. |
FrankMstein1446.00 |
08-24-2023, 03:43 PM | #266 |
864
Rep 663
I for all that matters will not fuel at shell or BP and use other top tier fuel stations. Even at 30-40c per gallon I’d rather save it and have a good whisky for those savings rather than give it away for the one of the most taxed product sold in the states. It’s not money thing. It’s ideological
08-24-2023, 03:52 PM | #267 |
2949
Rep 3,734
No, it is just fuel system maintenance.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-24-2023, 04:11 PM | #268 | |
3910
Rep 10,606
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
08-24-2023, 04:26 PM | #269 |
5778
Rep 11,305
As Shawn pointed out, some car makers are now adding port injection to DI systems to reduce carbon buildup.
shawnhayes1952.50 |
08-24-2023, 05:11 PM | #270 | |
1953
Rep 1,403
Your proposal that choice of oil is relevant while ignoring that significant gasoline contamination occurs frequently but top tier gas has "nothing to do with fuel solution" seems nonsensical to me. And NOTHING can prevent intake valve deposits. They can be minimized, but not prevented. Shawn |
08-25-2023, 08:03 AM | #271 | |
3910
Rep 10,606
As for my oil comment. All else being equal using high SAPS oils (LL01, LL01fe) can result in more IVD compared to Low SAPs (LL04, LL17fe). The 20w oil used by BMW in the US is low SAPS (ACEA C5) but that wasn't always the case with previous gen TGDI engines.
08-25-2023, 11:01 PM | #272 | |
1953
Rep 1,403
As far as SAPS go, now you're talking. High quality uniform carbon chain oil can be less volatile and not end up as oil vapor burning on valve stems. But that's not the ONLY cause of deposits. It has to be more complex than that. Shawn |
08-26-2023, 03:05 PM | #273 |
697
Rep 755
Lol all this ... The DI flaw in design is those dry valves. Ok, but the trade off is better combustion and power. I've considered Meth as a relief to keep those valves wet(ish) and possibly extend maintenance life. Also, I only see one mention of anyone using system or Injector cleaning agents separately. Interesting... Lol too about those penny pinching gas prices while driving a sports car. I'm sure they're not going to drop a $12 can of fuel system therapy in a tank, or every other tank, or every oil change (2-3000 miles). Lol
All of this, remember the RULES! You gotta PAY to Play! PICK YOUR POISON... CHEAP/FAST/RELIABLE Fast isn't cheap, nor reliable... Reliable isn't cheap or fast... Cheap isn't fast or reliable... If you're cheap, you get the worst deal! If you spend on fast, you can affect reliability, to an extent. You want it to work forever, well that's just boring! Lol Good Luck! |
08-27-2023, 12:43 AM | #274 |
1076
Rep 913
Use tier 1 gasoline and if only DI, walnut blast intake valves every 30K miles, no big deal. Italian tune ups whenever possible.
Two is One and One is None
08-15-2024, 09:05 PM | #275 |
11495
Rep 7,157
Drives: 2018 M2 AW DCT
Just an update. In my area Shells charges $.80 more for premium than for regular. While Chevron charges $.20 more for premium.
I am now a Chevron buyer. Interesting that Chevron premium is also cheaper than ARCO premium.
08-15-2024, 10:36 PM | #276 |
5778
Rep 11,305
Have not checked the nearest Chevron, but 80 cents difference between regular and premium is the norm in my area. I paid $4.29 per gallon the last few tanks for Mobil 93.
Was in Canada last month for a week and paid about 25% more than that. |
DanG11495.00 |
08-15-2024, 10:43 PM | #277 |
11495
Rep 7,157
Shell is $5.39 for premium and Chevron is $4.99 near me.
08-15-2024, 11:20 PM | #278 |
5778
Rep 11,305
Shell is more expensive than other top tier on my area as well. I rarely buy it. Sam’s Club is probably the best deal in my area and though I belong, I rarely remember to go there since it is less convenient. Sam’s is probably 5-10% cheaper and by some accounts is a top tier gas.
My wife uses the most expensive gas station in the area because it is most convenient. It is often 25-35 cents more per gallon, which adds up with a 22 gallon tank. I think she is trying to get me to fill up her car more. |
DanG11495.00 |
08-15-2024, 11:31 PM | #279 | |
11495
Rep 7,157
Westside Guy7320.00 |
08-16-2024, 02:04 PM | #280 |
278
Rep 427
I always have to fill her car.
DanG11495.00 Westside Guy7320.00 |
08-17-2024, 04:19 PM | #281 | |
1559
Rep 4,033
08-17-2024, 04:24 PM | #282 |
5778
Rep 11,305
08-17-2024, 11:02 PM | #284 |
5778
Rep 11,305
I guess I’ll stick with Mobil since it is the cheapest name brand and Sam’s club may or may not be good. I see no point in risk. I drove my 2008 E61 535xi to 150k miles on Mobil 93 with no issues. Many have injector problems. I did buy the car as a CPO with 30k and maybe something was replaced before I bought it, but I added 120k and no DI injector issues.
I know have a 2018 M5 and use almost exclusively Mobil 93 and no issues. |
DanG11495.00 |
08-17-2024, 11:42 PM | #285 | |
11495
Rep 7,157
