      11-05-2024, 01:37 PM   #1
boeitas
Drives: BMW i5
Most efficient way to change into and out of sport mode?
I just upgraded from a '22 i4 M50 to a '24 i5 M60, and I miss how easy it was to quickly drop into sport mode on the i4 - one button press on the center console, then going back to comfort was easy as well.
Having to tap "My Modes" on the console then potentially scroll and tap on the screen can't be the most efficient way, can it? I usually like to spend 90% of my time in comfort but then pop into sport for some brief twisties if there's no traffic.
I haven't been able to assign a shortcut, or one of the custom gestures to change the mode - hopefully I'm missing something obvious?
SkykingUSA3330.50
agorski473.50
      11-05-2024, 02:23 PM   #2
SkykingUSA
SkykingUSA's Avatar
3331
1,114
Maybe the quickest way is to say, "Hey BMW, Sport Mode". Another way, if you just want 10 seconds of Sport mode, is to pull the boost paddle.
Appreciate 4
ToddRGuy2497.00
Scrapula4614.00
paprmkr519.00
      11-05-2024, 02:42 PM   #3
LVBMW
LVBMW's Avatar
2541
1,219
Drives: '24 iX M60 '23 Tesla Model Y-P
Voice command as noted above.
SkykingUSA3330.50
ToddRGuy2497.00
Scrapula4614.00
      11-06-2024, 01:45 AM   #4
Elliston
Elliston's Avatar
United Kingdom
85
54
Drives: 3 Series M Sport (530e G61 on order)
Mine has not arrived yet but have been wondering the same thing. I use sport mode for over takes or when joining fast flowing traffic etc.
I have been trying to see what another flick down in the drive selector does if anyone knows. Park, neutral, drive then sport? Might depend on if the car is ICE, phev or full electric maybe?
In my current 3 series G20 you could flick the gear selector to the side to get sports gear box. Anything similar?
I am hoping the electric boost will help on these kind of things as my test drive car felt very responsive in normal drive mode.
Great tip on voice command, with more in depth menus that might be a good route now for a lot of settings.
SkykingUSA3330.50
Scrapula4614.00
      11-06-2024, 03:25 AM   #5
SkykingUSA
SkykingUSA's Avatar
3331
1,114
I don't believe there is any way to enter sport mode using the gear selector. For overtakes or joining fast traffic, the best way is probably to pull the boost paddle because it's instant Sport Mode, plus maximum power for 10 seconds (for the i5 models, not sure what it does on the ICE vehicles). That usually all you need to overtake or join fast traffic.
The drive selector can be pushed and pulled in two ways - sort of like the turn signals. You can pull it gently towards you to the first detent only, and it will move down one position at a time from Park to Neutral and so on. However, if you pull it all the way towards you past the first detent, then it will go directly into D. If you pull it back again, it goes into B on the i5 models (B is for one pedal driving). Pull it back again and it just toggles between D and B. If you push it forward one detent from D or B, that puts you back to neutral, or if you push it forward all the way, past the detent, then puts you in Reverse. There is no way to put it in Park using the gear selector. To put it in Park, just press the P button for the Parking brake, and that also puts the car in Park. Basically the gear selector lets you move between R - N - D/B (see the picture below). I hope that helps.
Scrapula4614.00
ToddRGuy2497.00
      11-06-2024, 12:09 PM   #6
nf0rc3r
89
23
Drives: BMW i5 eDrive40
Gesture of. 2 fingers forward is the easiest and fastest way
Appreciate 5
SkykingUSA3330.50
dfc888197.00
agorski473.50
      11-06-2024, 01:43 PM   #7
RichardInCA
RichardInCA's Avatar
4649
1,138
Drives: 24 BMW i5 M60
Agreed with Skyking - boost paddle is the easiest thing here, although depending upon which model you’re getting you may or may not need it. Even in personal mode my M60 will accelerate with urgency without needing to enter sport mode; I use sport mode more for stiffening up the chassis when the road gets a little twisty/fun or if I want a bit more of a sensitive throttle calibration.
Appreciate 4
SkykingUSA3330.50
Scrapula4614.00
dfc888197.00
      11-06-2024, 01:56 PM   #8
Elliston
Elliston's Avatar
United Kingdom
85
54
Thanks for the detail and the picture to support.
On my test drive (which was 48 hours!) I tried sports mode using the my modes route.
It wasnt until a few weeks later the issue of quickest route to do it occurred to me!
I tried to cover everything in those two days but some things it seems, always slip through.
Hopefully not too long to wait now.
Thanks 👍
SkykingUSA3330.50
agorski473.50
      11-06-2024, 03:16 PM   #9
madagil
53
Drives: BMW 540
In the 550e the drive selector has "D/S" rather than "D/B" as the bottom option. Pulling down moves from Drive to Sport mode. Pulling down again goes back to regular Drive.
Appreciate 4
      11-06-2024, 05:31 PM   #10
SkykingUSA
SkykingUSA's Avatar
3331
1,114
Thanks! That's great to know.
      11-06-2024, 07:12 PM   #11
Blue Sky
Blue Sky's Avatar
716
571
Drives: '14 M5 CP, '12 550i, '04 545i
All the previous 5s we had with auto transmission seemed to have something like this. On e39, e60 and f10 you pushed the shift lever to the left for sport or manual shifting, and back to the center to go back to regular drive. The DCT cars like the M5 had a hard button for drivetrain mode but that’s a different story.
SkykingUSA3330.50
      Yesterday, 01:15 AM   #12
BMW5151
316
116
Drives: 2022 M550i /2020 X3 M40i
2020 BMW X3 M40i  [10.00]
2022 M550ix  [10.00]
This is great news, thanks much.
Current:
'22 G30 M550i & '20 F25 X3 M40i
SkykingUSA3330.50
      Yesterday, 10:46 AM   #13
malpatti
80
154
Drives: 2021 540i xDrive
In the G30 when moving the gear lever to the left when in D it goes to S1 which I believe is different to Sports mode in that it only affects the transmission (and not throttle response, steering etc). Is that the case for the hybrid/ICE G60s? That is pulling down to S is not the normal sports mode it's only for the transmission?
SkykingUSA3330.50
      Yesterday, 09:43 PM   #14
paprmkr
BMW Enthusiast
paprmkr's Avatar
519
399
Drives: 2024 i5 M60 w/M-Performance ki
Gestures not allow for Sport mode. I use gestures to go back to personal mode
SkykingUSA3330.50
      Today, 01:14 AM   #15
nf0rc3r
89
23
I see. Must have been safety concerns. Thanks for the info.
I did recall some reviewer setting 505 gesture to sport mode? Maybe try that?
SkykingUSA3330.50
      Today, 01:42 AM   #16
AiredaleDad
AiredaleDad's Avatar
Spain
2322
673
Drives: 2025 BMW 540i XDrive
I set up gestures to go to MyModes, and just select Sport Mode with the push of the selector wheel.
SkykingUSA3330.50
      Today, 02:38 AM   #17
paprmkr
BMW Enthusiast
paprmkr's Avatar
519
399
Two updates ago it was removed. When I got car j was able to set it. Safety not sure. I wish we get set it as default
SkykingUSA3330.50
